Stupid leak-----D16z6------
Old 12-08-2003, 04:12 PM
HATCHingMN's Avatar
Default Stupid leak-----D16z6------
Its been asked many times before but I just need more information then what I have found using search!! OK.. so what could be causing this leak?? How to fix??
TIA!!!
Old 12-08-2003, 04:15 PM
SiR HatchAlot's Avatar
HEADGASKET
Old 12-08-2003, 04:21 PM
HATCHingMN's Avatar
Default Re: (sirhatchalot5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirhatchalot5 &raquo;</TD></TR><TR><TD CLASS="quote">HEADGASKET</TD></TR></TABLE>
R U sure?? I thought it might be that too!!
NE1 else??
Old 12-08-2003, 04:25 PM
Solbros Owns Me
Evs-One's Avatar
Default Re: (HATCHingMN)
probably not the head gasket...probably dist o ring or valve cover, etc
Old 12-08-2003, 04:28 PM
Eee Pee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirhatchalot5 &raquo;</TD></TR><TR><TD CLASS="quote">IF YOU SAY "IN MY HONEST OPINION" IN EVERY POST YOU MAKE, CONSIDER YOURSELF A HERB. i mean really, who the hell says IMO in an everyday conversation.</TD></TR></TABLE>
The same people who say "R U" and "NE1"....
I agree, a headgasket.
"Circle gets a square."
I thought it was the dist., but it wasn't.
Come to think of it, maybe it was cleaning up all three.
Old 12-08-2003, 04:31 PM
C uR eX's Avatar
Default Re: Stupid leak-----D16z6------ (HATCHingMN)
1) headgasket
2) cam seal
3) dizzy seal/ring
4) valve cover (but you should be able to tell)
that should be about it..but also look to see if the leak stretches any further like on the other end..
Old 12-08-2003, 04:33 PM
Global Moderator
Jimmy's Avatar
Default Re: (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">probably not the head gasket...probably dist o ring or valve cover, etc</TD></TR></TABLE>
What he said...
Old 12-08-2003, 04:39 PM
HATCHingMN's Avatar
I know for sure its not the valve cover beacause there is no leake arround the valve cover gasket!! I am leaning toward leaking dist. O-ring or headgasket!!
Say..if I sudden blow my headgasket would my motor make any noise?? I did noticed a slight decrease in accelleration/performance w/ that leak!!
Old 12-08-2003, 05:01 PM
booscivic's Avatar
check the O-ring from the ditributor
Old 12-08-2003, 05:29 PM
lohatch's Avatar
if it is the headgasket and you felt a loss in performance then you would probably be experiencing a slight loss in coolant or some oil in your coolant system, and your motor would probably run a bit hot sometimes. when my headgasket was fine my temp needle never went above the little temp symbol on the gauge, but once it was leaking it would go above it on occasion. is the oil on your dipstick foamy looking? i had a headgasket that was kinda leaking all summer and it finally went and all my coolant entered the motor and it was like a little white boosted steam engine screamin down the road. i was racing at the moment when she went good luck, hope that helps a little
Old 12-08-2003, 05:33 PM
Risky Business
BauleyCivic's Avatar
Default Re: Stupid leak-----D16z6------ (lohatch)
Hey I got that leak too! And its not coming from the cam seal or distributor...It's probably my headgasket not being torqued down enough...i'll get to it eventually
Old 12-08-2003, 05:48 PM
AmginE's Avatar
AHHH i have the SAME leak.
it's a ring on your distributor. Autozone/Oreilly wil want you to buy a new distributor. Honda will have a new gasket for about a buck 75. Go get the one from honda.
edit: i TOOK the Distributor OFF and it's a deteriorated ring. We put some of that ultra gasket crap on it, worked for a few months, and it's started again. Getting one from Honda ASAP.
Old 12-15-2003, 08:31 PM
Risky Business
Default Re: Stupid leak-----D16z6------ (AmginE)
BUMP...i'm having the same leak. Is this o-ring in the dizzy easy to replace?
Old 12-15-2003, 08:52 PM
Solbros Owns Me
Evs-One's Avatar
Default Re: Stupid leak-----D16z6------ (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">BUMP...i'm having the same leak. Is this o-ring in the dizzy easy to replace?</TD></TR></TABLE>
of course...pull the dizzy out and you can inspect it. Also check the outer cam caps
Old 12-15-2003, 09:43 PM
do you feel a perfomance loss or hesitation and a sound difference from the motor?
Old 12-15-2003, 09:45 PM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirhatchalot5 &raquo;</TD></TR><TR><TD CLASS="quote">do you feel a perfomance loss or hesitation and a sound difference from the motor?</TD></TR></TABLE>
nope...just phat *** oil leakage!
Old 12-15-2003, 10:04 PM
The Internet Tough Guy's Avatar
Default Re: (BauleyCivic)
ok i'm retarded... i don't think i'm seeing the leak... is that it right between the exhaust manifold heatshield and the upper radiator hose (right above the block code)??
Old 12-15-2003, 10:09 PM
Risky Business
Default Re: (jwn7)
Its between the block and the head on the passenger side of the motor where the tranny joins the block
Old 12-16-2003, 12:31 AM
Street Ghost's Avatar
my guess would be headgasket
Old 12-16-2003, 04:45 AM
length's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN &raquo;</TD></TR><TR><TD CLASS="quote">
NE1 else??</TD></TR></TABLE>
"Are you sure???"
"Anyone Else??"
Old 12-16-2003, 04:59 AM
SOHC_MShue's Avatar
my friend just recently had a similar leak on his b18c and it turned out to be the cam seals. So I would check there before assuming headgasket. We thought it was a headgasket at first, but thank god it wasn't.
Old 12-18-2003, 12:33 PM
aphex23's Avatar
Default Re: Stupid leak-----D16z6------ (d15nonvtec)
funny stuff, seems like a common problem, and to jump on the bandwagon, i also have some oil buildup on the same spot, also around the valve cover.. my dad think maybe i just gotta tighten the valve cover? we shall see when it gets warmer out!
Old 12-18-2003, 12:39 PM
SOHC_MShue's Avatar
Default Re: Stupid leak-----D16z6------ (aphex23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aphex23 &raquo;</TD></TR><TR><TD CLASS="quote">funny stuff, seems like a common problem, and to jump on the bandwagon, i also have some oil buildup on the same spot, also around the valve cover.. my dad think maybe i just gotta tighten the valve cover? we shall see when it gets warmer out! </TD></TR></TABLE>
did you remove your valve cover and forget to replace the gasket sealer? Either that or your gasket on the valve cover may be fucked. Either way its not gonna be an expensive fix for that.
Old 12-18-2003, 01:27 PM
d15nonvtec's Avatar
Default Re: Stupid leak-----D16z6------ (SOHC_MShue)
i gots the same prob on my z6, hopefully its just the dist ring, not the headgasket!
Old 12-18-2003, 05:37 PM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15nonvtec &raquo;</TD></TR><TR><TD CLASS="quote">i gots the same prob on my z6, hopefully its just the dist ring, not the headgasket!</TD></TR></TABLE>
Yep...I just went to the honda dealer to get the O ring...$3.20 (it was only supposed to be 1.70) Jim Coleman Honda likes to jack prices
I'll be replacing it tomorrow or next week and i'll post if it fixed the problem or not.
Quick Reply: Stupid leak-----D16z6------
