STUPID foggy windows!! plz help
Guest
Posts: n/a
hey guys, I recently lost my AC due to a crash i'v had a while back, I just got my car out of the body shop a while back...
ANYWAYS!! its been getting colder outside and its starting to rain.. the rainy season is coming for us here in TEXAS, and my windows inside gets all foggy and ****!!
what can I do to stop the foggyness without using the AC?
HT White Ops
Rub a bar of soap on the inside of the windows and buff it off with a dry towel.
Do not under any circumstances use the Rain-X anti-fog ****. All it does is put normal Rain-X (denatured alcohol) on the inside of your windows, smear around, make **** hard to see. Even when it does what it's supposed to, watter will run down the windows and behind your interior pieces, pooling up. **** never comes off, either.
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Dry bar of ivory soap. It's a ski'er trick. Used to do it to the inside of my goggles.</TD></TR></TABLE>
Damn, and I thought I was the only person who knew about this trick...
Re: STUPID foggy windows!! plz help (Type-Ek)
simply enough, crack your windows open a 1/4 inch and run the heat or defrost if its cold. i live in ohio and i drive my civic through the winter. they have terrible problems with defogging the window. if all else fails just crack the windows.
Re: (93EGB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93EGB18C1 »</TD></TR><TR><TD CLASS="quote">Damn, and I thought I was the only person who knew about this trick...</TD></TR></TABLE>
x3 i had an old wise man once tell me to do this and i thought he was joking.
Re: (SkyliteCP)
I used to use the AC when it was raining cause my windows would fog up real bad, but I learned I can use the warm defroster button for the front as well as the back.. It takes a few minutes to defrost, so while my car warms up I let it do it's thing. Much nicer to drive in rainy weather with clear windows and a warm car!
Re: (93EGB18C1)
just crack the windows a little and vent the heater, take the air from outside. works for me everytime. been driving with no ac for 5 yrs
Re: (fmrprojects)
if all else fails take the bus ... ahaha but seriously i just crack the window and if you are worried about a little rain water have a little towel you can drape on the door panel .. but if its pouringg *** rain - S.O.L
stop breathing inside the car....leave a window open....leave the cold air on the winsheild...there are a lot of things to do.
Re: STUPID foggy windows!! plz help (illusionz xx)
don't recirculate the air. saw someone post that up a few posts, and i think that's ubber important. i hardly use the a/c when it rains... all i ever do defrost using the coldest setting pulling air in from the outside. i'll have to try that soap trick...
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Rub a bar of soap on the inside of the windows and buff it off with a dry towel.</TD></TR></TABLE>
what if your windows are tinted? will it matter?
TEAM EoR
04-12-2008 03:44 PM
