Stumped...my rear main problem has returned...
Old 06-13-2004, 08:32 PM
Risky Business
BauleyCivic's Avatar
Default Stumped...my rear main problem has returned...
Well after replacing my rear main seal a month ago (read here: https://honda-tech.com/zerothread?id=845146 ) the problem has returned. Visible oil building up in the clutch housing and dripping out of the bottom. Rear main seal was replaced, the input shaft seal in the transmission was inspected, axle seals are fine....I really don't know where to look from here
Old 06-13-2004, 08:37 PM
ABK
ABK's Avatar
Default Re: Stumped...my rear main problem has returned... (BauleyCivic)
try to look on the the bellhousing seal. It will look like it's leaking from the clutch area but it really isn't. Put some die into the tranny then if it won't be green you can rule out the tranny. But I've seen the oil dripping on my friends car straight from clutch area, then after closer inspection I found out that it was a bellhousing/tranny seal right by the starter area.
Old 06-13-2004, 09:06 PM
Risky Business
Default Re: Stumped...my rear main problem has returned... (ABK)
It's not, I removed the dust cover from the clutch fork and saw that the inside of the bell housing was covered in oil. There was oil also coming from the starter hole as well.
Old 06-14-2004, 09:42 PM
ABK
ABK's Avatar
WTF looks like another long weekend ahhhh?
brenden747
13
05-27-2011 11:47 AM
hondachris1994
20
04-09-2007 06:22 PM
TylerC
08-08-2005 08:13 AM
skunkcoupe
17
12-29-2004 02:11 PM
overdose
04-23-2003 10:57 AM
Quick Reply: Stumped...my rear main problem has returned...
