STUMPED! - FUEL PROBLEMS!
sup peeps,
ok, before i begin... i have searched and read thru the archives of ht in this forum, and i still have unanswered questions to ask.
here's my situation:
engine: b18c5
harness: 98 si (obd2) w conv. harness (obd2-obd1)
ecu: p28 chipped
chassis: ek (97 hatch)
i got the swap in after many days and nights due to some unexpected interferences...
i got the car to start, and the problem starts from here...
1. im getting a CEL (code 6) - i think this is ECT (water temp sensor) --> how do i fix this?
2. the car "chokes" / "boggs" each gear when i rev it to 2500+
i have no power, and it almost seems like the car was gonna stall within those revs.
-so i checked the fuel pressure, and it read 80+psi (according to the b&m fp guage my friend had)
-im using a b&m fpr, and even when i lowered the adjustment, it still stayed the same reading: in fact, i swapped my oem fpr, and it still stayed at 80+psi. (what psi should it be anyway?)
- i know this is super rich, and this may be the main reason why my car is running like $hit with no power. but how am i supposed to be sure? is there a method to check or adjust (lower) the fuel pressure without purchasing a different fpr? could it be my stock fuel pump? filter? please help.... this is my daily, and it's been outa commission for a while now,,,
thanks in advance!
update: i bought a new fuel filter and changed it, but still no change!
engine: b18c5
ecu: p28 chipped
thanks in advance!
Re: (Zakar)
Stock fuel pressure is 42psi I believe...
Check out this link for a diag sheet for code 6...
https://honda-tech.com/zerothread?id=468260
Re: (Zakar)
yea i think its supposed to be 40ish too...
im not driving... i can't even drive past 2500 rpm.. i cant even go up a hill, no power
change the fuel pressure and try swappin in a new or a good known fuel pump. the water temp sensor is located right underneath the distributor, its the middle plug with one wire comin out. try replacin that to c if it clears the cel.
Re: (CivicSiRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiRX »</TD></TR><TR><TD CLASS="quote"> the water temp sensor is located right underneath the distributor, its the middle plug with one wire comin out. try replacin that to c if it clears the cel. </TD></TR></TABLE>
That is just the water temp sensor for the gauge in the dash, the one that the ECU reads from is the 2 pin connector off the thermostat housing (at least on my CRX and my EG) the EK's may have two, I can't remember for sure.
Re: (96-EJ6 B18C)
doh, ur right. its late, im tired. yes what he said, try replacin that piece. i switch mines out to a spoon sports one. works great. a stock one should be relatively cheap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96-EJ6 B18C »</TD></TR><TR><TD CLASS="quote">
That is just the water temp sensor for the Gauge, the one that the ECU reads from is the 2 pin connector off the thermostat housing (at least on my CRX and my EG). </TD></TR></TABLE>
Re: (NINE TRE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NINE TRE »</TD></TR><TR><TD CLASS="quote">thanks...
im gonna try this
It worked well for me. But I wasn't at 80 psi either, i was around 60. if it doesn't lower it enough, drill a larger hole. Just be careful not to drill it too large. The size bit they recommended worked perfectly for me.
im gonna try this
existanzcivicb20
27
07-11-2022 04:34 PM
Ekonte2
06-05-2005 11:15 AM
