Stuck in reverse!
Stuck in reverse!
My H22 hatch has been running good and last night after letting it sit for a little bit i went to leave and couldnt get into reverse. Got it turned around and would shift up through the gears with no problem, i continued home and once at idle tryed re-shifting into reverse and now it wont come out of reverse the stick will vertically but not horizontaly and no matter what direction it stays in reverse. Has anyone has this problem or no the fix, much appreciated. Thanks.
Re: Stuck in reverse! (PinoyDelSol)
TRANNY FLUID
OR
BAD CABLE. HAD THIS PROBLEM ON MINE CHECK THE CABLES AND FLUID
-If all else fails i hope you can drive in reverse really well
OR
Nerologic
13
09-28-2003 10:25 PM
