struts or coilovers???????????????
i got a eg hatch with a b18c and h&r race springs with deadass struts. Do you guys think i should change to a coilover setup or just get new performance struts? i drive the car everyday but i want a setup that will help me out on the drag strip. what are you guys out there with similar setups using for suspension? any info would be a huge help
thanks
thanks
Solbros Owns Me
Re: struts or coilovers??????????????? (dabomb)
you don't have struts, you have shocks. Your best bet is to invest in a full damper/coilover setup. By the time you by a new set of shocks and new springs-since yours will start to wear unevenly, you could have had a good set of Teins for a little more. Fully adjustable for different types of driving
Re: struts or coilovers??????????????? (Emerica)
shocks i dont think so. If you have to buget for actual coilovers go for it, but if not getting new performance struts will work fine for all your needs. I myself like jic coilovers.
If money is a factor then you should try a nice combo or ground control coil-overs and koni yellows or kyb agx's. But if the money is something that you are not really worried about then, I agree you should get some full dampeners such as Tein or Apexi N1.
