Strongest D Series Trans?
Old 12-01-2007, 10:32 AM
New User
chicagoboostin's Avatar
Default Strongest D Series Trans?
Ive searched, but it wont give me any results...
anyway, I'm doing to turbo my d16a1 and I was wondering what would be the best trans to mate to it.
Old 12-01-2007, 11:07 AM
ejoner's Avatar
Default Re: Strongest D Series Trans? (chicagoboostin)
Well I don't know about strength but the ex/si trannys have the shortest gears available for a d-series.
Old 05-14-2008, 08:52 AM
Rtboy10's Avatar
have gearspeed build you a 92-95 ex si tranny and you will never have to worry about it again. I've got a sohc that makes just shy of 300 and have blown out 2nd gear in the 92-95 dx trans twice in a week and in a 96-00 ex
Old 05-14-2008, 09:29 AM
gibsanez's Avatar
Isn't that the D series out of the first gen CRX?
Old 05-14-2008, 09:53 AM
bap168's Avatar
Default Re: Strongest D Series Trans? (gibsanez)
d16a1, that's a dohc D right?! First gen integra
Old 05-14-2008, 10:45 AM
obuhmyuh's Avatar
Default Re: Strongest D Series Trans? (bap168)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bap168 &raquo;</TD></TR><TR><TD CLASS="quote">d16a1, that's a dohc D right?! First gen integra</TD></TR></TABLE>
the only DOHC d-series that i know of is the d16zc DOHC non-VTEC.
[edit] D16A1
Found in:
1986-89 Acura Integra (USA)
Displacement : 1590 cm³
Bore and Stroke : 75 mm X 90 mm
1986-1987 Compression : 9.3:1 1988-1989 Compression : 9.5: 1
1986-1987 Power : 113 hp (84 kW) @ 6250rpm Torque : 99 ft·lbf @ 5500rpm
1988-1989 Power : 118 hp (88 kW) @ 6250rpm Torque: 103 ft·lbf @ 5500rpm
Valvetrain : DOHC non-VTEC
Piston Code 1986-87 : PG6
Piston Code 1988-89 : P29 (PM7 is ZC equivalent/same piston)
Fuel Control : OBD-0 MPFI
-wikipedia
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chicagoboostin &raquo;</TD></TR><TR><TD CLASS="quote">Ive searched, but it wont give me any results...
anyway, I'm doing to turbo my d16a1 and I was wondering what would be the best trans to mate to it.</TD></TR></TABLE>
ex/si tranny, I've got one on the way to my house right now (ex that is)
Old 05-14-2008, 10:48 AM
obuhmyuh's Avatar
Default Re: Strongest D Series Trans? (obuhmyuh)
i just read through that again haha it is DOHC... i never knew that. bap168 was right.
Old 05-14-2008, 11:14 AM
gibsanez's Avatar
What mounts do you plan on using? This isn't the same engine as the D16A6 you know
Old 05-14-2008, 12:16 PM
DCSportEJ1Civic's Avatar
get a 96-00 ex trans. its the same gear ratios as the 92-95, but had stronger shift forks. the 92-95's are aluminum and break easily.
Old 05-14-2008, 12:18 PM
Ice78transam's Avatar
Default Re: Strongest D Series Trans? (DCSportEJ1Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCSportEJ1Civic &raquo;</TD></TR><TR><TD CLASS="quote">get a 96-00 ex trans. its the same gear ratios as the 92-95, but had stronger shift forks. the 92-95's are aluminum and break easily.</TD></TR></TABLE>
x2 unless you gots lots of $$$
Old 05-14-2008, 12:49 PM
obuhmyuh's Avatar
Default Re: Strongest D Series Trans? (Ice78transam)
my ex tranny just got in from nippon-motors, its in great condition and even came with a starter haha.
Old 05-14-2008, 12:56 PM
Swerv's Avatar
Lookin good bro!
Is that the one you got for $300? I'll take one too, please. :-p
Is it rebuilt or used?
bap168's Avatar
I have a d16a6 tranny out of a 90 CRX Si for sale.
Old 05-14-2008, 01:00 PM
obuhmyuh's Avatar
Default Re: Strongest D Series Trans? (Swerv)
it was 350 and they delivered it to my doorstep
it looks brand new and this one came from a JDM d15b, so far installing it tonight/tomorrow
Old 05-14-2008, 02:57 PM
1.5Slowmatic's Avatar
yes but when the 92-95 forks break, they break. 96-00 bend and cause more damage than just the forks. Better to go with an earlier EX/Si trans, less damage casued when a fork goes
Old 05-19-2008, 09:53 AM
Default Re: Strongest D Series Trans? (1.5Slowmatic)
well when mine broke the both broke, put a 3 inch hole in the side of my trans case, and destroyed both of my shaft bearings. the trans was worthless after that. ill stick with my jasper racing trans. $1500 well spent imo. and before i hear it from everyone i dont care if you think it was a waste of money. after replacing 4 transmissions i got tired of wasting my money on the same junk.
Old 05-19-2008, 10:19 AM
speedooo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCSportEJ1Civic &raquo;</TD></TR><TR><TD CLASS="quote">well when mine broke the both broke, put a 3 inch hole in the side of my trans case, and destroyed both of my shaft bearings. the trans was worthless after that. ill stick with my jasper racing trans. $1500 well spent imo. and before i hear it from everyone i dont care if you think it was a waste of money. after replacing 4 transmissions i got tired of wasting my money on the same junk.</TD></TR></TABLE>
qft.
i had a z6 trans last from sept-nov 06: blew the diff, 2nd, broke the fork
i had a y8 trans last from nov 06-march-07: no second gear, grinded third all day, popped out of gear, eventually blew the diff
some douche sold me a beat dx trans that popped out of second, third, fifth, grinded third and fifth, i eventually broke the fork
i got a mint z6 trans rebuilt by my homie at honda in august of 07-never grinded, never popped out of gear, no noise, then my car was stolen in october
then i got a new eg, put a z6 trans in it and blew it up in 5 days
d series trans FTL.
Old 05-19-2008, 10:48 AM
jdmeg6118's Avatar
Default Re: Strongest D Series Trans? (speedooo)
How are you guys always bending fork's?? And what causes "pop outs"????
Old 05-19-2008, 11:42 AM
Default Re: Strongest D Series Trans? (jdmeg6118)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg6118 &raquo;</TD></TR><TR><TD CLASS="quote">How are you guys always bending fork's?? And what causes "pop outs"????</TD></TR></TABLE>
Beating the hell out of the tranny causes bent forks, lol.
and pop outs are often caused by worn gears that have been rounded off slightly due to excessive grinding. Sometimes misalignment is also the culprit.
Old 05-19-2008, 12:03 PM
ferio252's Avatar
It's not automatic thats for sure.
AT's ftl
Old 05-19-2008, 12:18 PM
blk92_d16's Avatar
I completely agree with 1.5Slowmatic, because that's what Bone has said for years. There isn't a "stronger" tranny, it's just one that won't cause you to throw an ENTIRE trans away instead of just the forks.
Ex/Si is the way to go!
Old 05-19-2008, 12:46 PM
just.me.ek5's Avatar
Default Re: Strongest D Series Trans? (ferio252)
is a d16 tranny for a y8 a good tranny for a mini me swap?
Old 05-19-2008, 02:09 PM
Default Re: Strongest D Series Trans? (just.me.ek5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by just.me.ek5 &raquo;</TD></TR><TR><TD CLASS="quote">is a d16 tranny for a y8 a good tranny for a mini me swap?</TD></TR></TABLE>
yes either a y8 or a z6 are good all around.
Old 05-19-2008, 02:28 PM
Aquafina's Avatar
You have the strongest D trans. 5th is seperated from the rest of the gear by a built in brace to the case. Shafts are thick, gears are thick. Has decent ratios too.
Old 05-19-2008, 03:18 PM
2fasteg6's Avatar
Default Re: Strongest D Series Trans? (ejoner)
ex/si
jdmshawn95
02-09-2011 06:46 PM
minime-civic
08-23-2007 08:55 PM
drewbie
03-23-2006 08:21 AM
Aero Deck
03-22-2004 06:53 PM
gribbs
10-18-2003 12:23 PM
Quick Reply: Strongest D Series Trans?
