Stripped bolt head on rearLCA <-> Subframe ---- HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: Stripped bolt head on rearLCA <-> Subframe ---- HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!! (Declecti
torch it. get it red hot and it should loosen it up. drill a hole in the middle of it, and use a reverse drill bit to pull it out.
Your best bet is gonna be to use an easy-out, but considering that the head broke off trying to loosen it, that bolt is probably pretty stuck in there. You could always get a drill bit thats a little bit smaller than the hole and just drill the whole thing out.
