str cam gears
Old 10-23-2003, 07:37 AM
vtec94civic's Avatar
Default str cam gears
does anyone know how many degrees each mark equals. i got mine in the mail yesterday, but there are no instuctions and it only moves like 2.5 marks each way. if anyone knows let me know. i'm guessing that each mark equal 2 degrees so that you 5 degrees adjustment both ways. thanks
Old 10-23-2003, 08:18 AM
-Trinitron-'s Avatar
Default Re: str cam gears (vtec94civic)
are they the new ones? with markings around the majority of the gear or the older ones with very small marks between 2 of the bolts?
Old 10-23-2003, 10:32 AM
Default Re: str cam gears (-TRINiTRON-)
they are the new ones. str 570
Old 10-23-2003, 11:37 AM
BDL IND's Avatar
Check out our site to determine how to degree those in.
We wanted a new and innovative design that would help tuners degree in their Cam Gears Easier and Faster.
Find "0" they meet up in the center
If you want to go three degrees advance count 3 marks from "0" on the outer counter clockwise and do the same on the inner. Now align the two marks. We spaced it out for easy reading and adjustment.
Old 10-23-2003, 11:41 AM
Down Since Day 1
1 point 6's Avatar
Default Re: str cam gears (STR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STR &raquo;</TD></TR><TR><TD CLASS="quote">Check out our site to determine how to degree those in.
If you want to go three degrees advance count 3 marks from "0" on the outer counter clockwise and do the same on the inner. Now align the two marks. We spaced it out for easy reading and adjustment.</TD></TR></TABLE>
thats dope, now all you have to do is make the gears come in hot pink and theyd be perfect.
Old 10-23-2003, 12:09 PM
thanks for the help. i didn't see the link on the site when i was first was looking around. guess i just wasn't looking good enough, but i see it now and now i understand how to adjust them.
scspeed
09-16-2008 11:39 AM
StraightNoChaser
05-31-2008 04:17 PM
DaInFaMMuS1
05-02-2008 02:37 PM
nebulight
09-03-2006 08:07 AM
b18crx
02-20-2004 12:38 AM
Quick Reply: str cam gears
