Stock Tach Accurate?
Old 04-08-2002, 10:53 AM
New User
gsrvx's Avatar
Default Stock Tach Accurate?
I have a 92 VX (which comes with a stock 8Krpm tach)...and the gsr motor is going in pretty soon. I'd really like to keep the tach...since it'd be more of a sleeper..but how would it work? Would the needle go past 8Krpm because of the higher gsr redline? Would it be accurate up to 8K?
My other choices are:
1. Install an autometer monster tach. I have one sitting here and collecting dust. A friend gave it to me...so might as well put it to good use. I like that it has a shift light...but hate the fact that it's so huge.
2. Find an si cluster. Looks stock but the problem is that all the sellers i've found are asking too much for it. Would anyone happen to know someone selling a cluster?
Well...lemme know what ur opinions are. Thanks guys.
-Rod
Old 04-08-2002, 11:04 AM
Spade's Avatar
Default Re: Stock Tach Accurate? (RK)
Swap a 99-00 Si guage cluster.
And no, stock tach's are not accurate......most type R tach's read 9100 at fuel cut off (8400).
Old 04-08-2002, 11:11 AM
New User
HENRY's Avatar
you should definitely upgrade your cluster to an appropriate tach. Si clusters from the 5th gen civics would fit but their redline is still too low since it was always meant for a D16z6. You should either get a JDM cluster (higher redline) or there is a guy on this board that does a really nice job of converting GS-R clusters to fit 5th gen civics. The 99-00 Si cluster would not fit without major mods. One last thing you could do is get a Apex vtec controller (you probably would want one anyways for tuning) and that gives more precise RPM readings then tachs do.
Old 04-08-2002, 11:20 AM
blacksheep's Avatar
Default Re: Stock Tach Accurate? (Spade)
How in the hell is he going to put a 99-00 Si guage cluster in a 92 VX? I would just use the stock one, or buy a 92-95 EX/Si cluster. I hate those huge monster tachs.. they look too ricey. The stock ones may not be as accurate at the monster tach, but they won't be far off. And after a while you learn where the needle is when the rev limiter kicks in anyway, so you'll know when to shift.
Old 04-08-2002, 11:27 AM
neveronlines2k's Avatar
Default Re: Stock Tach Accurate? (HENRY)
I agree with HENRY just buy a V-AFC it is more accurate and you can tune with it. that = $ better spent
Old Member
GoLowDrew's Avatar
If you are wondering about accuracy, then it doesn't matter. No stock tach or speedo is right on the money to begin with. There is always +/_ across the entire range. So I really don't expect the aftermarkets to be any better.
Change it because you like the look, don't do it because you are worrying about accuracy, unless it's defective.
Old 04-08-2002, 11:37 AM
Malachi's Avatar
Default Re: Stock Tach Accurate? (blacksheep)
heres the links on this discussion
https://honda-tech.com/zerothread?id=87465
https://honda-tech.com/zerothread?id=87466
Old 04-08-2002, 12:43 PM
TurboBumblBee's Avatar
-Rod
stock tachs suck.. i have a 95 civic ex and broke the stock tach when i was messing w/ wires behind my dash.. i installed a monster tach that was more accurate but it is no where accurate as my vafc.. since i have installed the vafc and will be swapping in a b18c1 very soon i installed a 94+ integra gsr cluster.. all it requires doing is rewiring the cluster wiring and making it fit in and look good w/ a dremal tool.. it only took me about 3 hours to rewire and make it fit and work correctly.. and btw, the integra cluster is also off from the vafc
Old 04-08-2002, 01:15 PM
PSU
formerly DxHatchback
PSU's Avatar
Default Re: Stock Tach Accurate? (95CivicEX)
nice
Old 04-08-2002, 01:21 PM
eg6ajk's Avatar
Default Re: Stock Tach Accurate? (DxHatchback)
most stock tachs such as SI/SiRs are about 100-300rpm off at RPM below 5000rpm.....above that it goes up to 200-500rpm
mines is off only by 200-300rpm at 8500rpm
as far as speedo most are off by 5-10mph
Old 04-08-2002, 01:46 PM
New User
gsrvx's Avatar
Default Re: Stock Tach Accurate? (eg6ajk)
Hey thanks for the replies guys. About the VAFC....wouldn't it be hard to read though? It's a digital reading of the rpm correct? I would imagine that the digits would be quite small.
-Rod
Old 04-08-2002, 02:07 PM
Banned
acura_typer's Avatar
to make it look good with a dremel tool? I doubt it....I've seen hack jobs like that..this is so much nicer.
Old 04-08-2002, 03:19 PM
just go to the moniter setting in the V-AFC on 1 channel and it will be a farely large display. Tust me it will be large enough and very accurate.
Old 04-08-2002, 05:01 PM
Pat McGroin's Avatar
Default Re: Stock Tach Accurate? (stuckatworksi)
wow glad this issue was brought up, pheewww
Old 04-08-2002, 05:11 PM
Default Re: Stock Tach Accurate? (acura_typer)
yes that does look nice.. i could have put one of those into my car but then i would have to buy it for $250 i like the way mine looks and have gotten many complements..
[Modified by 95CivicEX, 11:22 PM 4/8/2002]
Old 04-08-2002, 08:41 PM
New User
gsrvx's Avatar
Would anyone happen to have a picture of this?
-rod
DCRB
10-10-2008 08:25 PM
klungemonger
11-06-2006 07:18 AM
mugenhatch92
03-29-2006 07:21 PM
Jesterian
24
08-25-2005 04:04 PM
EpDarks
11-17-2002 09:34 PM
Quick Reply: Stock Tach Accurate?
