Is This A Stock Driverside Motor Mount?
Re: (numberone)
yeah i agree that its not a stock bracket. I would really recommend that you upgrade mounts being that the h22 swap weighs about 200 lbs more than a b-series.
EDIT BY MODERATOR:
It does not weigh 200 lbs more than a b-series. Get your facts straight before you provide misinformation.
EDIT BY MODERATOR:
Re: Is This A Stock Driverside Motor Mount? (xXSilentScreamXx)
The mount appears to be stock, but the bracket is def. not. I would highly suggest upgrading mounts considering stock ek mounts where probably never meant to see the torque an hp of an h22.
Re: Is This A Stock Driverside Motor Mount? (Brian Hinson)
my friend has that same kit on a 400 whp LS ek and never had any problems...
you are fine with that...
you dont need to change that mount..
Re: Is This A Stock Driverside Motor Mount? (Ekb18c5_BR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2mansi »</TD></TR><TR><TD CLASS="quote">yeah i agree that its not a stock bracket. I would really recommend that you upgrade mounts being that the h22 swap weighs about 200 lbs more than a b-series.</TD></TR></TABLE>
An H22 does not weigh 200lbs more than a B series.
Re: (xXSilentScreamXx)
The bracket is definetly not stock. If your mount is ripped then you should replace it. I would look into getting a driver's side mount made specifically for an H22 into an EK.
Ekb18c5_BR
my mount is ripped in half?
do you mean i dont need another bracket?
i have tried looking but idk were any one would sell just the driver side after market h22ek mount
that is a stock mount but the bracket is for b series to h series motor swap which you have! also it looks like your mount is already ripping! you can drive it for as long as you want but when you shift you will felt it jerking if you dont rev match. oh and you also lose power because the tires dont have 100% contact when it moves like that. i just put in polyurethane insert mounts and it feels pretty good
You dont really look that hard I guess.
Hasport- http://hasport.com/products/mounts.htm You need the EKH2 mount kit or you can contact them and buy just the driver's side mount.
Avid Racing- http://www.avidracing.com/motormounts.html You would need part number AC MM 03. You also might be able to contact them and order just the driver's side.
If you want to be really cheap you can hit up ebay and find a whole mount kit for 100 bucks. They probally suck, but better than what you have now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx »</TD></TR><TR><TD CLASS="quote">how long can i drive with it like this? will i break anything?</TD></TR></TABLE>
Im suprised you werent breaking anything even before the mount ripped. You need certian mounts for the H22 in an Ek because of the way the motor sits. Even with the correct mounts alot of people still tear through axels because of the angle the motor sits in the bay.
O16581724 5 2 5
05-30-2005 10:35 PM
Sir_Phobos
11
04-10-2003 09:13 PM
