stock 99 SI engine/ecu problems
ok so im cruising along with the ac on and the cruise control on as usual. about 2 miles later i realize im not going as fast. so i turn the ac off no change in speed i hit the gas which i realize is to the floor already. then the cel comes on and flashes at me 104 the first time then 110 times then it repeats. above 3000 rpms it runs ok but has loss of power in it below 3000 the engine shakes the whole car the lower the rpm the worse it is til it feels like an old muscle car at idle. had ecu checked got misfire on cylinder 1 then i got imobilizer to pcm signal error. what the hell is that?? the ecu will not reset at all. changed plugs still same thing
please give any info you may know thank you
99 civic si with completly stock b16
and please bump up for me so i can get my car running right again
Modified by civictildeath at 2:04 AM 6/6/2006
ArrizownEM1
08-24-2012 01:41 PM
