Stock 94 Civic Ex bogs
Got a 94 Honda Civic Ex with a stock motor with about 200,000 miles on the cluster. The recent maintenance that was done before and after summer was: fuel filter, cap and rotor, coolant temperature sensor, spark plugs(new ones as of now).
The thing is that at certain speeds of 15-20 mph, the car feels like it will jerk when you put your feet on the gas pedal. The same thing also happens at 60 mph when i'm cruising at that speed unless i push on the gas pedal more. And around 70-75 mph, it slightly happens too.
I came upon some hypothesis that the car maybe misfiring. Do ya have any suggestions?
Re: Stock 94 Civic Ex bogs
Have you checked compresson and timing? Does it burn oil or coolant? Thats an a$$ load of miles it might be time for an overhaul.
To answer those questions: 1) Yes, the spark plugs are evenly gapped and I didn't do the timing. A friend of mine is a Honda man so he touched my timing when we changed the timing belt. 2) No CEL even on the TPS (Happened before but my former co-worker used a multi-meter to fix it already) 3) I haven't checked the compression on it yet but it's not burning any oil or coolant. The only time it burns oil is when it is engaged in VTEC. 4) The plug wires seemed to be oldest out of the maintenance but i will check on that. It may need new ones.
Mr learns alot
02-28-2014 08:11 PM
carlos8
01-16-2014 03:43 PM
baileygirl
31
03-19-2012 12:09 PM
CPTN
05-21-2011 09:25 PM
