Still have running problems with the EG6. Help required !
Still have running problems with the EG6 Civic. Help required !
Hi guys,
I posted a thread up not that long ago saying i got water in a spark plug chamber and it caused poor running, eventually leading to cutting out the engine and the coil pack breaking.
New coil pack in and its a lot better as it will start now. Problems is when i give it load its like someone is retarding the ignition. There is no real power.
Now im onto a 2nd hand didtributor thats know to work and still the same problems.
I fitted the original dist back onto the timing markings i made aswell to make sure it would run ok first turn of the key.
I hooked up a timing light to look for a mark on the bottom pulley but i cant see anything at all. No markings on the pulley !
How is it i time the engine then ?
Thanks in advance !
Modified by John F at 7:49 PM 10/14/2005
Thanks in advance !
Re: Still have running problems with the EG6 Civic. Help required ! (John F)
Put a timing gun onto the bottom pulley and the timing mark will only appear on the bumper side of the pulley. I can swing the dizzy back but the timing mark wont appear on the firewall side of the pulley.
AH !
AH !
if you can't see anything your timing must be off, same thing that happened to me.
