still getting ecu code 1
I just replaced my O2 sensor with a universal 4 wire bosch, but I am still getting check engine error code 1(it blinks once every 5 seconds). What could be wrong? BTW, i have a b16a2 swap with P72 ecu.
Re: still getting ecu code 1 (miataguy)
check your wiring. trace the conections and see if you're getting anything.
also have you resetted the ecu, after the installation?
Re: still getting ecu code 1 (eg6ajk)
you had a 5 wire o2 sensor before right?
i had same problem every 1 here said get a new o2 sensor which is not the case
you need to run the orange/blue wire from the firewall side to the white wire on the harness
don't mess this up b/c i did now my car dosen't start
The existing O2 sensor was 4 wire...i just spliced the new one on. Do i need to do anything special to reset the ecu? I thought you just needed to disconnect and reconnect the negative terminal on the battery
damn i got the same damn problem. i replaced my o2 sensor. but my cel keeps coming on. (not right away but after im takin in into high rpms) i got a gsr swap and im runnin the si ecu.
Re: still getting ecu code 1 (BlVlW313)
i had same exact problem it was from going from 5 to 4 wire o2
well, did you splice the 02 sensor in right? On the bosch universal ones the black wire is the sensor wire, not the ground. I did that initially myself. Might be something to check.
s
s
Re: still getting ecu code 1 (stevel)
I spliced the two blacks to two blacks, the white to blue, and green to white, according to the instructions. Is this not right?
sounds right from memory. the bosch universal I got had 2 white wires, a black, and a gray. little different but it looks like you did it right. have you hooked up a voltmeter to it to see if it's working correctly?
s
s
I've replaced the 02 sensor with an oem denzo, and it still doesn't work! I've replaced the ecu with a chipped p28 in the mean time so it can't be the ECU. I don't know what to try next.
CLE
05-28-2007 10:14 AM
accordianex
13
03-03-2006 05:30 AM
