Sticky gas pedal?
Sticky gas pedal?
I have a 1998 Civic LX Automatic. The gas pedal is difficult to depress...sometimes I'll be sitting at a light and when it's time to go I'll put my foot down on the pedal and I won't be able to push it down. So, I'll push harder and harder with my foot until I can push the gas pedal down...But at this point I'll have pressed it so far down that I end up flooring it so the car shoots off and all of that. What should I do to fix this problem? Suggestions appreciated. Thanks!
Re: Sticky gas pedal? (ejprimo)
It's not the floormat. How do you check the cable? Check it as in lubricate it or see if it is damaged? How could I tell if it is damaged if so?
Re: Sticky gas pedal? (Campee)
i work for a honda dealership and we have seen those cables get messed up replace the cable and pay close attention to the routing of the cable upon reinstallation
Re: Sticky gas pedal? (b18a1boosted)
No. But I'm going to guess you don't have too much shop time under your belt, so to play it safe, go buy a manual for the car. Helms manual preferrably, but a Haynes will do. Follow the directions.
