stereo prolbem
Old 10-25-2009, 03:27 PM
hatch92civic's Avatar
Default stereo prolbem
When i bought my civic it had a cheap kenwood cd player in it and i had a eclipse cd from another car i had sittin in my garage. The plugs for both stereos were the same type(i guess wires were in a different configuration) So i pull the kenwood out and pluged the eclipse in, turned on the key and after about 10-15 sec the deck started smoking so i turned the key off and unplugged it. I check the radio fuse and it was blown so i replaced it put the kenwood back in and it doesnt work. no other fuses are blown or wires fried. anyone have any ideas on what could be causing the deck to not work?
Old 10-25-2009, 03:35 PM
MHDesigns's Avatar
Default Re: stereo prolbem
Lol you killed it. You probably shot power to a cord that shouldn't have had it and fried the **** out of it. Take it to a professional, that's gonna be the only way to tell. Good luck, but you should start looking for another deck. Always read wiring diagrams before you install stuff.
Old 10-25-2009, 04:01 PM
fried the decks or the wiring?
Old 10-25-2009, 04:03 PM
Colonel Cake Mix
acake em1's Avatar
the deck most likely.. look for another head unit man
Old 10-25-2009, 04:51 PM
how would it have blown the original kenwood deck? what would cause the clock not to work also?
Old 10-25-2009, 05:04 PM
Colonel Cake Mix
acake em1's Avatar
the deck you plugged in that started smoking is shorted out most likely... and you prolly blew your radio and clock fuse when u did that... next time either pull your fuses or disconnect the battery
Old 10-25-2009, 05:14 PM
r22thomas's Avatar
smoke came from the eclipse, how would the kenwood magically be fried. I vote check fuses then check voltage on wires then harness
Old 10-25-2009, 05:30 PM
gwl
gwl's Avatar
Recheck the fuses under the dash and hood.
Get a volt meter and a wiring diagram for your car.
Without the radio installed, measure the voltage coming out the harness and check if you have the standby voltage. With the key at the on position, measured for power on voltage.
Old 10-25-2009, 06:00 PM
Colonel Cake Mix
acake em1's Avatar
the kenwood isnt fried... he fried the eclipse, which sucks cause thats the better stereo
Old 10-25-2009, 07:29 PM
found that the back up fuse under the hood was blown, replaced it and now its all good.
Old 10-25-2009, 07:37 PM
Colonel Cake Mix
acake em1's Avatar
what about the stereos? does the kenwood one work at least
methos713
Audio / Security / Video
01-15-2008 05:41 AM
JDM_SOHC
10-16-2005 07:08 PM
Steezn4NOReason
11-23-2004 11:28 PM
WuShu
10-05-2001 10:22 AM
Quick Reply: stereo prolbem
