step by step b series swap? i searched.
Banned
i went through the archive and i couldnt find any exact how too's. like what all will be needed? what problems i might run into, wiring etc.. a link would be greatly appreciated. i understand i will need different mounts and a different shift linkage, as well as axles, but what about wiring, clutch slave mount up..minor things. thanks.
Re: step by step b series swap? i searched. (strictly.business)
its the same thing as the single. easy in, easy out...if obd1, get a 94-95 integra gsr engine harness, or a obd1 del sol harness and you should be good.
Banned
well, the b16 is going into my 96 ex coupe..can i use the harness that comes with the obd1 b16 that im buying? do i need a conversion harness? or can i just use the b16 harness and ecu?
Re: (strictly.business)
go to c-speedracing.com, they have a step by step diagram on a how to.
as far as the harness if the b16 is a obd2 your fine. if it's a obd1, get a conversion kit. it'll make your life easier.
Civicman86
01-25-2006 08:43 PM
