Stcok D16, Charge it or Swap it???
When the time comes i was gonna turbo my 1.6 but then i thought for the money why don't i do a swap. What would be the best engine swap for my car? And like the best money/speed ratio. And if anyone knows a good place to go let me know.
1 Post
Re: Stcok D16, Charge it or Swap it??? (JasonBlackEJ1)
come on now hes just askin a question, no use in being mean, i asked the same question on another board, but id go ahead and do a swap, i heard turboing a D series is great and everything but it lacks midrange. plus you would be much more happy with a swap. trust me.
Re: Stcok D16, Charge it or Swap it??? (skribblah)
if the motor is in good shape boost it
if not swap in a b18 or bigger
my d16z6 blew up before i could boost it
so i swaped in a b16a
it sucks
so now im boosting that
i think a turbo d16 would be cheap and fun
do a search for turbo d16 or something like that
look for dyno numbers
see if they are appealing
good luck
it sucks
good luck
Re: Stcok D16, Charge it or Swap it??? (mOuse)
Charge it... I turbocharged my Z6 for around $1700(used greddy kit). I considered a swap for a while, but decided against it. Right now I'm running 8psi and will be upping it to 10 within a week SOHC VTEC=
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mOuse »</TD></TR><TR><TD CLASS="quote"> And like the best money/speed ratio. </TD></TR></TABLE>
lol, I've never heard that one before, good terminology.
It's your choice, there is plenty of arguments for either option. Just do some research and base your decision on that. If you need more info on turbocharging a d16, there are a couple sites in my sig. you could check out, or keep searching archives on here. Just be aware, when you do a swap, most likely you spend whatever it costs for the engine/tranny, labor (if it applies), and a little for any extras that might come up and you are good to go. With a turbo setup, things can add up quickly. You likely won't be done with buying a kit (like GReddy), you still probably want to have a boost gauge, an intercooler, an EGT gauge, a blow off valve, maybe an A/F gauge, possibly some fuel system upgrades, oh and then you could get a larger diameter exhaust to improve spool up, may need a new heavier duty clutch, maybe a lightened flywheel, while you're at it you can upgrade to Hondata or something similar, then you can.....
See what I mean
See what I mean
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonBlackEJ1 »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerosearch</TD></TR></TABLE>
how is that being mean? i would reccomend the turbo too. rebuild it first if it has alot of miles on it b/c mine blew up too (threw a rod). ive heard of a lot of d16s throwing rods and its a bitch to have to fix.
Re: (mOuse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mOuse »</TD></TR><TR><TD CLASS="quote">It has 116k miles on it, now what do you think about a turbo?</TD></TR></TABLE>
whoa. um.... hmm thats quite a few. I have the same and i would think you'd have to rebuild it so you don't have a mishappenining like the one stated above. **** i was thinking of a turboing also, but now that I think about it...
Banned
Re: (slow_a$$_eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_a$$_eg »</TD></TR><TR><TD CLASS="quote">
whoa. um.... hmm thats quite a few. I have the same and i would think you'd have to rebuild it so you don't have a mishappenining like the one stated above. **** i was thinking of a turboing also, but now that I think about it... </TD></TR></TABLE>
**** IT!!!! Booooooost that ****!!!! and buy a new engine for 400 bucks when it blows..... and BOOOOST THAT ONE TOO!! you see, thats the beauty of it.... if you blow your single cam, you can go out and get another one for the cost of a header for a Bseries... tell me that isnt just comforting
Re: (Irishweird00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Irishweird00 »</TD></TR><TR><TD CLASS="quote">
tell me that isnt just comforting </TD></TR></TABLE>
Yes my friend, it is comforting, very comforting indeed.
If you want NA set up, i would go with b18c.
if not i would turbo charge d16. and if you get more money i would work on internal.
Re: (Irishweird00)
**** IT!!!! Booooooost that ****!!!! and buy a new engine for 400 bucks when it blows..... and BOOOOST THAT ONE TOO!! you see, thats the beauty of it.... if you blow your single cam, you can go out and get another one for the cost of a header for a Bseries... tell me that isnt just comforting </TD></TR></TABLE>
Thats come funny ****, You are the man. But anywya thanks that post basicallly decided for me, your right if the SOHC blows I can get another for cheap. My next question is i need to save as much cash as possible for college and stuff, where can i get a cheaper turbo, possibly used if used are any good. Thanks
Re: (Irishweird00)
Re: Stcok D16, Charge it or Swap it??? (5thgencivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivic »</TD></TR><TR><TD CLASS="quote">Charge it... I turbocharged my Z6 for around $1700(used greddy kit). I considered a swap for a while, but decided against it. Right now I'm running 8psi and will be upping it to 10 within a week SOHC VTEC= </TD></TR></TABLE>
do you have times with 8psi?
UnKnOwNsLeEpEr
04-26-2004 03:54 PM
