starts, idles, wont go over 2k rpm.. ek hatch jdm h22
itll start and idle, it just wont go over 2 thousand rpms, i thought tps at first but he put in a new throttle body and that didnt help.. any suggestions?
it just chokes out at 2 grand..
Modified by A08 at 3:16 PM 10/5/2007
Re: starts, idles, wont go over 2k rpm.. ek hatch jdm h22 (A08)
I would first check the ecu(for any codes), then the rest of the ignition, because if the car will idle but not rev the only thing that could be holding the car back would be fuel,
Re: starts, idles, wont go over 2k rpm.. ek hatch jdm h22 (metal craft)
i dont think its resistor box, ive only seen too much fuel be added when the resistor box is fucked up and it causes it to flood..
as far as the fitv... we're checking it but i dont see why that valve would make it choke out after 2 thousand rpms..??
hey if the car runs or idles well, then stay with
Kiss
Keep
It
Simple
Stupid
it has to be something very simple, if you have checked the intake, ignition system and reset the ecu, I know its not the fast idle valve the only problem with that is erratic idle, I know this since I have problems all the time with my fast idle valve, I have JDM b16a swap, and I have had almost every problem with that car, it may be the distributor, and that is the only thing it could or should be
Kiss
Keep
It
Simple
Stupid
Re: starts, idles, wont go over 2k rpm.. ek hatch jdm h22 (sleeper_civic_4dr)
u in the army lol? we say that in the army "kiss" anyway.. ill have him check the distributor..
does it stop at 2000rpms and surge up and down if it does its gota be dat FICV ive did 3 cars like dat its da only thing i know it could be i know its not da dizzy.
bOOSTin5th
11
01-23-2019 05:14 PM
bnmm
Engine Management and Tuning
08-31-2011 10:41 AM
