starting up turbo
starting up turbo
i didnt install my walbro fuel pump yet still have factory in can i start up my car? im not going to drive it in the streets jsut wanna hear it. im going to install the walbro fuel pump when my bro gets home to help me
Re: (DecentCivicZ6)
thanks guys im boosting only 7psi and tryin to run it a month or 2 with no tune untill i have money for my tune its ok right?
where can i connect the vac. on my wg to? on a b16a2. Can i tap to the pipe connect to my turbo
Modified by EK4_SI at 12:12 PM 7/11/2007
Modified by EK4_SI at 1:33 PM 7/11/2007
B A N N E D
should have a nipple on the turbo near outlet, and run that to bottom of wastegate. But 7 psi with no tune, no anything...is gonan be wack, youre gonna break ****...its gonna do nothing but throw CEL. and once that CEL comes on, all power is gone, just boggs and pops and does nothing until you restart the car. I suggest waiting 2months for ATLEAST basemap and a lil street datalogg/tune. cause you will throw NO cel with that, and it will retard timing for you as you gain boost...and runs so much smoother and safer.
Re: (DecentCivicZ6)
there's no nipple near on the outlet on my turbo. can i drill it on the pipe connected to the outlet?
For the post below me. Im new i didnt know there was a fi sectio. but thanks for telling me, i cant post more then 5 a day that why i have to edit this one
yea can you post up some pics please DecentCivicZ6
Modified by EK4_SI at 2:20 PM 7/11/2007
Re: (EK4_SI)
No offense, but if you dont know enough about turboing a honda to hook up vac lines to a wastegate you probably should'nt run around with out a tune. Get a tune. Your car will thank you and so will ur wallet when you dont have to rebuild your motor.
Re: (BlakeJ53)
ture...i'm getting a tune before i run it. Theres another problem i have right now tho i cant put on my down pipe cause it hitting some thing above my oil pan so i cant take it to the shop.
so i cant run my car with no downpipe/o2 sensor right. im pretty sure
for the post down there i have rc550 injectors/fuel pump/hondata s100... im going to get it tune before i run it tho i dont want anything to blow up lol...
ps: had to edit this one cause i can only post 5 a day cause im still a NOOB lol
Modified by EK4_SI at 10:20 AM 7/12/2007
Re: (BlakeJ53)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK4_SI »</TD></TR><TR><TD CLASS="quote">thanks guys im boosting only 7psi and tryin to run it a month or 2 with no tune untill i have money for my tune its ok right?
Modified by EK4_SI at 1:33 PM 7/11/2007</TD></TR></TABLE>
LoL
No, running it at 7psi for 2 months untuned is NOT gonna be okay...lol, you don't have any extra fuel management there?
LoL
B A N N E D
Re: (Syndacate)
also, no you do not need a down pipe or O2 sensor to run the car...you can drive it to the shop like that no problem, just dissconnect a boost pipe first, so u do not boost any. wont hurt a damn thing.
[IMG][/IMG]
and i got a closer up pic of my old super 60 t3.
[IMG][/IMG]
goes right there where that hole is, where the metal is rasied up.
[IMG][/IMG]
[IMG][/IMG]
Re: (DecentCivicZ6)
that bro...is it ok if i tape it to in pipe connected to the turbo? cause i already did
is this the right map sensor for myu motor?
http://www.digi-key.com part number MPX4250AP-ND
B A N N E D
tape what into the pipe? the o2??? you dont need the o2 just to goto the shop.... I ran my car turbo for 4months with no O2...I had a wideband that we used to tune it with, but afterwards i jsut plugged the hole.
But why doyou need a map sensor? you plan on boosting past 14.7 psi? thats only way you will need a new map sensor. and they are like $60 for gm 3bar map.
Re: (DecentCivicZ6)
oh sorry for the typo haha..what i meant was instead of tapping the wg hose to the tubo like you have above in the pictures can i tap it threw the innercooler pipe thats connected to the turbo?....i got confused while typing this lol sorry if i dont make any sence haha
and i need the map sensor cause imma going to ge tmy car tuned at 11-14 psi this comming up week and the motorola map is cheap around 28 bucks
Modified by EK4_SI at 6:06 PM 7/13/2007
thumper64
01-16-2010 09:38 PM
turbocoupe
11-18-2001 07:19 PM
