starting problems
starting problems
ok i have a 00 si that i just had a valve job done and i put it all back together adjusted the valves put it in time and tried to start it and it wont start..its gettin a good spark and its getting fuel.. i dunno what else it could be can anyone help.. thanks
Two Piece
Re: starting problems
people make mistakes sometimes.
i would double check.
the car we have here has spark, starter is good, its getting fuel but no start.
we took the spark plugs out and they were wet with gas. check your plugs and see if they are wet and smell of gas. if they are its possible your engine is flooded, which is causing the car not to start
are you certain everything is in time correctly i did timing belt on my gsr the other day and was about to install the new belt when I noticed I had it 180 degrees out I lined up the cams lined up the crank with the tdc mark then noticed the little "up" on the cam sprockets was facing "down " lol I've been wrenchin 20 + years and almost put the new belt on like that ! yeah all the marks were lined up but the word up was not facing up I caught it and its all I can think of to try to help ya out its worth checkin
Isn't the stock compression for the 99-00 si's generally are right around 210?
I'm not sure but I just did a quick google.. I think our 97 EX was generally 165 if I remember correctly.
I'm leaning towards "flooded" as well.
when we did my friends car he had the same problem we messed wit it for days took the whole motor apart and put i togeather and still no start finnaly we re-adkusted the valves and it started
tom48
01-30-2011 01:54 PM
