starting problem
starting problem
hey guys whats up?...well i have a91 hatch with a b16 swap...im having starting problems...
it used to be only on cold starts that i would have to turn the engine like four times before it actually started...but now it does it all the time....
i try priming the pump three or four times before starting to see if thats the problem but doesn't work...i've changed the fuel filter on it just in case....
any ideas?....please help
this is really pissing me off.... [IMG][/IMG][IMG][/IMG]
Re: (slamdcivic)
Honda OEM are the better choices... there was a thread with dyno numbers comparin NGK blues(brand new), MSD(brand new), and Honda OEM wires(which were used and old) and the Honda wires made the most power... just a thought...
Change the plugs and wires, and if its not that check ur dizzy, if its not that check ur starter... You should buy a Helms manual bro....
kikacha
06-29-2007 02:52 PM
