Starter won't start HELP!!!
Hello.
A few days ago, I was running around town...parked my car when I went into a mall. Car was running fine. EK, 1998 CX hatch, D16Y7, injen intake, apex'i WSII exhaust. Came back out an hour or two later, wouldn't start.
All that happens when I try to start my car is hearing the master relay and starter solenoid click. Can hear fuel pump humming a little too. Doesn't even try to start turning over, just nothing.
I've checked the master relay, can't find any component damage/solder problems on the pcb. I also installed a whole new starter. Couldn't find any loose grounds or power cables either. Checked voltage, getting 12.6V, but no current. No odd noises when I turned it off for the last time, so I'm pretty sure it isn't siezed or anything like that.
Any ideas what I should check next? I really need to get this car on the road again as soon as I can.
Re: Starter won't start HELP!!!
have you tired tapping on the starter while someone is turning the key?
if not just grab a hammer and hit the starter not to hard but a couple good thumps.
try jumping a wire at the starter to see if it turns over, make sure car is in nuetral first if is turns over its possible your clutch safety switch went bad
I'll check out the ignition switch idea though...
Yeah mines a manual. My friends coming over to help me hit it with a hammer. But like the OP said, I can hear it clicking under the dash board, by the fuse box fairly often. Not every time but like 30% of the time.
Any other suggestions?
Your probably gonna want to check at a few different locations for juice. I'm assuming you have already jumped the starter externally to make sure its engaging. Remember just because you get something new, doesn't mean its not junk. After that, what i'd suggest is following the route in the wiring back to the ignition checking it at relevant locations.
If it were a manual i'd advise you to try a push start and see what happens.
Well first make sure you can get it to engage freely, and it sounds like nothings seized up from what you say. You could also have a starter that will not fully engage under a load. I just had one of these in my shop a few weeks ago.
Hope that helps.
Hope that helps.
thought it might have been the starter so I got it tested and its fine.
Tomorrow Ill try to get the battery checked and see if thats the problem. If thats not it then Im lost
Ive push started / jump started my car twice since the starter "died" and it runs / drives just fine.
Thanks again for the advise
I had the same problem a while back just with a few more problems. It was my transmission ground. I took it off cleaned up the wire on both ends and wirewheeled the contact on the chassis to bare paint and it ran beautifully
Ok...an update.
Magically, I tried starting the POS, and it started just once, just enough to taunt me. Revved it a few times, turned it off and tried again. Wouldn't start.
I took my 75A battery charger/starter, and boosted the starter directly (I realize that the starter actually takes about 340A to operate fully, if memory serves). Funny thing happened...the starter kinda started spinning, choking a few times, and then fully spooled up after 2-3 attempts. Being its first actual use, maybe the starter was having a few hiccups. Car still wouldn't start after this, so it really wasn't the problem. So it seems that the starter solenoid is getting the signal, but can't draw the current to spin the motor.
I realize I said earlier that I checked out my main relay a while ago, and said it was fine. After boosting the starter, I'm starting to think that it really is the problem...burnt out contacts, perhaps?
I have the relay on order, since I live in a crappy town consisting of 90% trucks, and 50% of those being dodge. Be here tomorrow. Here's hoping its not a waste of money
The starter is connected to two wires, a large Blk wire running directly to the battery and a Blk/Wht wire for the solenoid that gets power through the ignition switch. Disconnect both wires at the starter, and then use a voltmeter to:
1) Check whether the Blk wire at the starter has battery voltage regardless of whether the ignition key is ON. My guess is that you will find the problem here.
2) Check whether the Blk/Wht wire has battery voltage when the transmission is in Park and the key is turned to ON(III). I think this is fine as you hear the solenoid click.
As mentioned, double check that the transmission ground connection is clean and tight. Also clean the battery posts, connectors, and ground wire with steel wool and then tighten.
I'm telling you man... I'm almost 90% sure this is where your problem lies. Check what ron said and im willing to bet its all comes out good.
So
weak battery + poor grounds = strange **** happening.
Clean that trans ground GOOD on all contact points and I'm willing to bet it'll start right up.
So
So
At the same time, I'm not feeling at all cheated about this...I've seen starters go at the most inopportune times (roadtrip, 200km from the nearest shop or parts store), so I'm kinda happy I got a new one in.
i had this problem once.. it only happens in the winter, and this was with a new starter, i just tapped on it a couple times and it started right up.. like a dead cell.. for those that have same prob and havent fixde
