Starter Peoblems.... I think
Location: Buffalo / St. Paul / and on weekends Plainview, MN
i recently did a swap in my civic and it sat for about a week after the swap was completed. well two weeks ago i put insurance on it and started to drive it the first day i drove to work about ten min from my house picked up my check and when i got back to my car it wouldn't start so i got a ride home and grabbed my accord to jump it assuming that was the problem. it started with out being jumped. so i went home a put a new batt in my car. and still had this problem. so i got a new starter for it and still have this problem. So any help at all would be much appreciated
Re: Starter Peoblems.... I think (Campana13)
did you solder all ur wires when u spliced and connected them? it could just be loose wire. it would help if u told up what car and year and what motor and year. it could also be that u used wrong obd components too.
Re: Starter Peoblems.... I think (98B00STED)
The car is a 92 CIvic 4 door and the Motor is a D15B7. we also did the auto to manual coversion at the same time we did the swap
Bump cuz my car still wont start
EDIT: Acctually now taht you mention it i did have some clutch problems with it right away. it is still soft but engages like an inch from the floor.
Modified by Campana13 at 11:39 AM 9/13/2004
my house has wheels on it
have you checked the clutch switch? i had similar problems with my gsr/ek would have to hold the key in the start position and stomp the clutch pedal up and down
turn the key on and make sure that shifter selector thing is in the park position. try slidin that around a little tom and see if that does it and put that thing in a place where it wont get bumped and ****. see how that works
Re: Starter Peoblems.... I think (lohatch)
Got it fixed guys there were mice living out side my garage and they chewed threw half of my ground wire on the underside of the wire but got it fixed now and the car runs great. Thanks for all the help
when the problem occurs have you unplugged the signal wire to the starter and chked for voltage...? if there is no voltage it could be ur starter switch... i would start frm there and work my way towards the ign switch... good luck...
Hatch'd
05-31-2005 09:44 PM
