starter issue
Ferio Wdm Edition
starter issue
Hello!
I recently did a auto to manual swap, and it seems the starter is acting funny. My bro and i put in a starter and sometimes it woukd start, and other times id have to hit the start. So after we inspected it, we switched the start solenoid with the known auto, and same thing. We hooked up jumper cables to the start, and ran a bar from the ground, to the positive, and it would start spark, and activate everytime. So we put it back in the, and of course, it wouldnt crank ..so do you guys think the screw is to blame?
Ferio Wdm Edition
Re: starter issue
I still have the shifter assembly hooked up...but i stuck a thumbtac to stop the slider from moving. I talked to my pops, and he said the auto and manual starter internals are different..thats true? We getting power, and a ground signal from when the key is turnt
Ferio Wdm Edition
Re: starter issue
Oh actual testing votage? No we didnt do that, he just had the test light on it, we was worried to see if the starter was getting power still....my bro is going to pick up another starter tomorrow, so i will report tomorrow.
Re: starter issue
You need to make an actual voltage measurement. But what did you use as ground with the test light?
Ferio Wdm Edition
Re: starter issue
Ill pass that on to my bro...so you think the issue could be the starterim tempted to get a manual starter, and see if that does it, or the shifter sliding piece moved over a bit.
Re: starter issue
Did you buy a different starter? I was reading a auto to manual swap DIY yesterday and it said they are different starters. It might just not be meshing up correctly or engaging at all.
Ferio Wdm Edition
Jack Murphy
06-21-2017 06:23 PM
Offspring EK
22
12-09-2009 04:55 PM
B18CivicEH2
05-06-2009 05:29 PM
