Stalls when idleing
Stalls when idleing
Hi everyone, i am new here and desperly need help. I recently bought a 1997 civic cx hatchback. Since then i have bought new wheels and an exhaust. I decided it would be a good idea to put some sort or security/anti-theft device in it so i decided to put in a hidden kill switch. So i went out and bought a toggle switch thats rated at 10A. So i cut the live wire to the fuel pump. To see what would happen if it was started with no power to the fuel pump, i tried tried to start it and it died within 2 seconds. Perfect. So i soldered in the 12gauge wire and the toggle switch and put everything back together. Then i tried to start it with the switch off and it didnt even start. Then i turned it on and it started and ran fine for 5 minutes. Later that night i took it for a ride and when i came to a stop sign it stalled out on me and it kept doing that all the way around the block whenever it came to an idle. What could possibly be causing this? Could it be something wrong with the computer when i disconnected the battery to solder the wires? Please help!
Re: Stalls when idleing
Either you cut into the wrong wire for the fuel pump, or you have a fault connection somewhere.
I solder my map sensor for my turbo setup and i would get a code for map sensor voltage high. It only happens sometimes. Clear the code and all good.
Then a few months later check the wiring and found out the connection had broke after the solder joint and was just touching.
So yea check the wiring and switch.
Tyson
06-07-2004 06:38 PM
