which stainless steel brake lines?
well guys i'm getting ready to do my whole brake and suspension upgrade and i'm wondering which brake lines to go with and where's the best place to get them and thanks in advance
Re: which stainless steel brake lines? (singlecam screamer)
Ive heard nothing but good things about the Goodridge Stainless Brake Lines. as far as where to get them, im not sure.
here is one place: http://www.nipponpower.com/brake/bra...dge_honda.html also if your intrested, here is comptechs version: http://www.eautoworks.com/html/ORD-A...de-No-6244.htm |
Re: which stainless steel brake lines? (krnbk2)
i gotts earls... der purdy https://honda-tech.com/forums/images...s/emsmilep.gif
i dont think theres much of a difference between them and the goodridge, but they will both improve performance over the stock ones. https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: which stainless steel brake lines? (euclid)
Go with Earls they are the masters of braided lines, they are what I run are they are great.
Re: which stainless steel brake lines? (gsr_vx_hatch)
I hate to hijack this thread, but Ive been wondering something. If you have upgraded your brakes, say Integra discs all wheels on a Civic, which line kit do you buy? Do you still buy the kit for Civics, or do you go with the Integra kit?
Re: which stainless steel brake lines? (piscorpio)
anyone tried russel? Where can you buy earl's lines? I'm upgradeing mine soon.
Re: which stainless steel brake lines? (civicmatt)
Where can you buy earl's lines? |
Re: which stainless steel brake lines? (ejprimo)
Ive been wondering something. If you have upgraded your brakes, say Integra discs all wheels on a Civic, which line kit do you buy? Do you still buy the kit for Civics, or do you go with the Integra kit? |
Re: which stainless steel brake lines? (slowrider)
goodridge.. and you buy the lines for the brakes you are running.... ie civic cx with gsr brakes, you buy gsr lines
HTH [Modified by CRX25, 6:53 PM 1/17/2003] |
Re: which stainless steel brake lines? (CRX25)
goodridge.. and you buy the lines for the brakes you are running.... ie civic cx with gsr brakes, you buy gsr lines HTH [Modified by CRX25, 6:53 PM 1/17/2003] |
thanks guys but as far as what brake lines to use wouldn't you use the civic lines because of the length
I believe the larger brakes probably require longer lines. When I swapped my VX fronts for Sir fronts, the line coming from the caliper is a bit tight. That is to say, it reaches, but it has very little slack. I was concerned about that enough to consider buying new lines, I worry about stretching the ones on there that don't seem to fit quite right.
Re: which stainless steel brake lines? (DMS Racing)
i got gsr suspention on 95 cx.got goodridge lines for 92-95 civics.have no problems.
Re: which stainless steel brake lines? (TEAM JSJ)
I heard goodridge is good.
[Modified by Unjockable, 12:58 AM 1/18/2003] |
Re: which stainless steel brake lines? (Unjockable)
get goodridge they are not expensive...and they have lifetime warranty...cant beat that.
DEF i think the warranty is the winner |
Ive heard nothing but good things about the Goodridge Stainless Brake Lines. as far as where to get them, im not sure. Manchester Honda http://WWW.manhonda.com that's where i got mine. |
