stabilizer bushing help! Really annoying.
I swapped in my urethane bushing almost a year ago. Has been great and I have nothing bad to say about it. I replaced my throwout bearing this weekend, and ended up dropping the shifter along with this bushing to avoid playing with the bitch pin. I mount the tranny, put everything back on fine. When it comes time to put this bushing back on, I notice that I can't get it to be perfectly flush. There is a little gap in between the bracket and the urethane. (not between the urethane and the car though).
The shifter is super sloppy. I have a lot of vertical play in my shifter. It also goes with the torque of the motor, which is really annoying. Is there any sort of washer or something I could be missing? I took it off again to only have the car be the same exact way.
Grr.
Could something near the motor be loose? When I shift (or when someone else does) the linkage moves through the bushing itself.
Only reason why im wondering if this is the problem is because I did it.
My friend put on the rest of the shift linkage.
Modified by japearl at 10:20 PM 12/5/2005
Grr.
Re: stabilizer bushing help! Really annoying. (japearl)
yooo dude, you are missing the bracket that holds that bushing in place... see where the bolt hole is?
mrbuddha
01-28-2011 12:30 AM
SoullessJapaneseMachine
14
04-11-2010 11:21 PM
