SSR LCA for eh?
SRR LCA for eh?
I could not find the SRR website and was wondering if they ever came out with some LCA's for EH/EG?
P.S B18c5 is crazy
[Modified by Black HB, 6:04 PM 9/7/2002]
[Modified by Black HB, 6:05 PM 9/7/2002]
P.S B18c5 is crazy
Former Moderator
Re: SSR LCA for eh? (Black HB)
Try SRR
SSR is the maker of some really nice wheels, while SRR makes the LCAs.
I'm not 100% sure, but I *think* they are for the EK only as of right now. I could be wrong though since products are being introduced every day.
Try A-J Racing. Anyone got their site handy?
[Modified by B18C5-EH2, 11:52 AM 9/7/2002]
Re: SRR LCA for eh? (Black HB)
Well if anyone cares i've been talking with SRR and they are sending me some LCA's for EG ill keep anyone posted if anyone cares :D
FYI - SRR = Made in Taiwan
yeah i would like to know about them. hey if you speak taiwanese i have some questions about their stuff if you dont mind relaying the message. hell i will ask you now i saw their steering rod or tie rods or something on ebay a while back and would like more info. I havent even seen them on their website
gold wheels holla !!!
Re: SRR LCA for eh? (nijia555)
They told me the steering rods or whatever are for offroad use only, has spherical bearings,said that a pothole and speedbumps would mess them up a bit, i looked into those too.
Re: SRR LCA for eh? (Apex i ITR)
ok i have them on my ek and yes they have a hole for your enlinkd but they are not prethreaded like the stock gsr lca's. Also they do NOT come with endlinks because they put all the holes in there bars close to factory locations on there bars so that factory hardware can be used. As far as anything else, they are purely cosmetic cause they way the same if not more than stock rear lca's. I got mine cause i got them for a pretty good deal and i had a cracked lca and needed a replacement. If you are doing it just for the hell of it then i don't know if it will be worth the money.
[Modified by SilverCivic2k, 4:07 PM 9/10/2002]
Re: SRR LCA for eh? (Eddie HatchBlack)
I would like to see some pics when you get them.
Here are some LCA for EH's
http://www.specprod.com/TEMP_DIR/TEMP_69100.HTML
not prethreaded eh..... hmmmm
Re: SRR LCA for eh? (rolow)
Re: SRR LCA for eh? (speshuled619)
the srr ones do, i don't know about the ones on the site above. The hole is drilled but it is not threaded, you will have to have a washer and nut on the other side of the lca to keep the endlink attached.
Re: SRR LCA for eh? (SilverCivic2k)
They are also shorter to correct camber, and create clearence for bigger/wider tires by narrowing the track in the rear.
