SRS Light...Normal?
SRS Light...Normal?
When I put the key in the ignition of my 2000 Ek Hatch the srs light stays solid for 6 seconds or so and then goes out. It doesnt beep or blink or do anything else like it used to. Is this normal or did I do something? The Ek has stock motor and everything seems to run/work fine.
Re: SRS Light...Normal? (Type Ek)
completely normal, while that light is on for the 6 or 7 secs, the computer is doing a system check to make sure everything in the srs system is working right...if the light ever syats solid, then you have a problem in your srs system and your airbags will NOT work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type Ek »</TD></TR><TR><TD CLASS="quote"> Up For Answers! </TD></TR></TABLE>
volkdlr
11-08-2004 09:26 PM
