SRS light.... NEED HELP PLEASE!!!
Re: SRS light.... NEED HELP PLEASE!!! (RIDIN JDM)
what is wrong with the SRS system that is causing the light to come on? Fix the problem instead of pulling the light......you do want your airbag to deploy in an accident right?
Re: SRS light.... NEED HELP PLEASE!!! (SRCivic97)
I thought I head somewhere that the 96-98 civics had a recall advisory or something like that... for this very problem. In fact I sold a buddy of mine a 96 DX and he said he was having the same problem... not sure what came of it, but I think he was going to take it by Honda for a free service/update of some sort. ? But, yea, try searching on the issue as well...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SRCivic97 »</TD></TR><TR><TD CLASS="quote">SEARCH </TD></TR></TABLE>
roger that...
https://honda-tech.com/zerothread?id=264288
roger that...
Re: SRS light.... NEED HELP PLEASE!!! (EliteCivicX)
Reset the light and see if it comes back on, if at all to rule out a fluke. If it returns, trouble shoot from there.
if you have fitted a non-airbag steering wheel then the srs light will stay on regardless... this happened when i did a steering wheel swap on mine.. all you need to do it take out the dial cluster and remove the srs connecters from it.. its the orange clip with 2/3 wires connecting to it, roughy the bottom centre of the cluster.
works a treat
works a treat
Re: (Zani)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zani »</TD></TR><TR><TD CLASS="quote">if you have fitted a non-airbag steering wheel then the srs light will stay on regardless... this happened when i did a steering wheel swap on mine.. all you need to do it take out the dial cluster and remove the srs connecters from it.. its the orange clip with 2/3 wires connecting to it, roughy the bottom centre of the cluster.
works a treat</TD></TR></TABLE>
Thats a good idea, who needs warning indicators anyways?
Did the light come on randomly, or did you install something/change something within the car that made it come on?
Re: (jlacoy82)
[QUOTE=jlacoy82]
QUOTE]
"Clark, why is the car still running?" "All new cars do that honey...You hate it now, but wait till you drive it." -Metallic Pee Family Truckster-
QUOTE]
Re: SRS light.... NEED HELP PLEASE!!! (SPNFEDEJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEJ »</TD></TR><TR><TD CLASS="quote">reset your ECU</TD></TR></TABLE>
How do i do that just unplug and plug it back in?
Re: SRS light.... NEED HELP PLEASE!!! (JDM EK9)
Re: SRS light.... NEED HELP PLEASE!!! (93_cxEG)
i did mine a different way i just lifted the cover slightly and with a knife poped out the bulb. mine came on after i installed a momo steering wheel
