SRS Light
SRS Light
Can someone help me turn this damn thing off???
I have a 1995 Del Sol.
I looked in the fuse box under the dash, but saw 2 yellow plugs. WHICH ONE do I use??
Then what??
PLEASE e-mail me -- littleredvet@earthlink.net
THANKS!!!!!!!!!!!!!!!!
Then what??
H-T Order of Merit
Re: SRS Light (Wray)
Not sure what the plugs look like but if there is only one plug with only two pins then use that one.
Here is a link for the instructions.
https://honda-tech.com/zerothread?id=264288
Re: (AzCivic1.6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzCivic1.6 »</TD></TR><TR><TD CLASS="quote">is the brake fluid cap on all the way?</TD></TR></TABLE>
ummm what the hell would that have to do with the air bag light being on?
H-T Order of Merit
Re: SRS Light (linda02916)
ok, first thing. Whatever it is that set off your SRS light, whether it be unpluging the driver seat and starting the car or blown airbags, you need to fix it before you can reset the light. If you unplugged your driver seat and started the car then just plug the seat back in, if it's the blown airbags replace the airbags and module. If it's not fixed then your light won't go off.
Re: (Donkey85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donkey85 »</TD></TR><TR><TD CLASS="quote">
ummm what the hell would that have to do with the air bag light being on? </TD></TR></TABLE>
SRS...ABS they sound the same. i read too quickly.
first you would have to take out your cluster and then unplugg the harness i forget which one but you will find out it wont cause any electrical problems if you tried taking one out and turn the key to a/cc
H-T Order of Merit
Re: (iiiskipiii)
SRS...ABS they sound the same. i read too quickly.</TD></TR></TABLE>
lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iiiskipiii »</TD></TR><TR><TD CLASS="quote">first you would have to take out your cluster and then unplugg the harness i forget which one but you will find out it wont cause any electrical problems if you tried taking one out and turn the key to a/cc</TD></TR></TABLE>
What are you talking about and who is it directed towards?
lol
Re: (RabbittZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RabbittZ »</TD></TR><TR><TD CLASS="quote">just take out the cluster and remove the light bulb???</TD></TR></TABLE>
Or unplug the yellow plug behind the cluster.
Not stuiped. It serves two purposes 1 the most important one to me is that it stops the annoying seat belt chim from coming on after a min or two of driving along with the flashing light that distracts you, 2 most new cars ob2 i belive have a black box that store the last 10-15 seconds of data b4 a crash to help investigators ext so by having that unpluged it shows that your seat belt was on the whole time.
Re: (scratchy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scratchy »</TD></TR><TR><TD CLASS="quote">you are retarded</TD></TR></TABLE>
what the hell are you talking about chump?
Re: (jbs)
Don't want to uplug the light.. when the light is on the airbags won't deploy.. I want them to work....
Guess I'll have to take it to the dealer... Can't seem to get the needed info here...
Thanks anyhow... ;-)
H-T Order of Merit
Re: SRS Light (nocternaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocternaldragon »</TD></TR><TR><TD CLASS="quote">Not stuiped. It serves two purposes 1 the most important one to me is that it stops the annoying seat belt chim from coming on after a min or two of driving along with the flashing light that distracts you, 2 most new cars ob2 i belive have a black box that store the last 10-15 seconds of data b4 a crash to help investigators ext so by having that unpluged it shows that your seat belt was on the whole time.
So your saying you drive without your seatbelt on?
I have never tried unplugging my seat and trying but thats what I heard, so I guess I heard wrong. Either way, I wouldn't unplug my seat anyway. I always have my seat belt on and don't have that black box, even if I did I still wouldn't unplug it.
H-T Order of Merit
Re: (Wray)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wray »</TD></TR><TR><TD CLASS="quote">Don't want to uplug the light.. when the light is on the airbags won't deploy.. I want them to work....
Thanks anyhow... ;-)</TD></TR></TABLE>
Yeah, I wouldn't unplug the light or the harness from behind the cluster. Do it the right way.
And what do you mean no one gave you what you needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">
