SRS help
SRS help
well my srs light is always lit up on the cluster...i dont know why...i replaced a new oem airbag on there but the lightn still pops up its kind of annoying if you know what i mean, because you are driving at night and its dark and a red glare stands out at you...i appreciated anyones help who knows how to fix this problem...thanks
Re: SRS help (beefjerky)
http://www.norcalrcrew.com/index.php?categoryid=13 Simply use a paper clip in place of the srs service connector
^Try this if it doesnt work
Go through an inspection station have them hook it up and it can tell you why the light is on. Or if you dont need to go through inspection you could always just take off the cluster and remove the bulb for SRS, And problem solved until next inspection. Or you could always just take it to honda and have them check it for you what engine do you have, ecu changed out or chipped? Give a lil bit more info.
blackdog
02-03-2005 11:26 AM
