Squeek really annoying need help
Squeak really annoying from back right tire need help
yesterday i put my si rims back on and everything is tight and everything i have brembo drilled/slotted rotors and this really load squeak comes from the back right rotor when i make a left turn, and once i got straight it stops. I took the wheel of turned the rotor and every spin it would grab and be hard to turn it past that one point but then smooth through the rest of the turn put it back on and the same thing. Any one have ideas could it be a bent rotor or is it just something else.
any opinions please thanx guys
Re: Squeak really annoying from back right tire need help (Themouse)
Could be a warped rotor (And one of the reasons I hate drilled aftermarket rotors - they warp easily)
However, since it appears you are only getting the sound when you are cornering, I would bet you have a wheel bearing that is going bad. But without looking at it personally, I cannot be certain. It has to be one of the two (Those are the only two parts that move and have contact with non moving parts.
thanx for the help yeah i'm going to have it looked at but if was just the weirdest thing bacuase i went from my steelies for the winter to my SI's and now i get the noise but i dunno and some times it will make the noise while i am straight but its like once in a blue moon
thanx guys
thanx guys
Eresuncabron
10-22-2003 01:19 PM
