Squeaky front end. 2000 ex
My car developed a squeaking recently
It occurs when you turn the wheel and sometimes if there is suspension travel
It is only the right side , I crawled under and I could see some of the rubber
Cracked and missing around the lower ball joint , is my ball joint on the brink if snapping?
I sprayed some silicone lube on it and it quieted down "some"
But it's def still there, Suggestions?
Re: Squeaky front end. 2000 ex
the uppers you can replace the whole arm so it just bolts in. but the lowers are pressed into the spindle so if you don't have a balljoint press you might want to take it to a shop . but you can rent them at most parts stores
PatrickGSR94
Suspension & Brakes
18
05-12-2010 09:55 AM
K2e2vin
31
11-02-2006 06:46 PM
