sputter
sputter
ok i recently put a d16y7 into my 92 vx and i have not been able to get it to stop sputtering once it warms up it starts to sputter. more when i come off idle and into throttle i changed distridutor new fuel pump and wires im not sure if i have the iacv wired right thow because its a 3 pin can anyone help
Re: sputter (chucka64dr)
maybe the filter is dirty try pulling it out and spraying some carb cleaner in there, but get it really clean otherwise it wont work. your idle is going up and down right?
Re: sputter (civiccpedx)
also you may need to check it anyways because my 94 civic does the same thing and the check engine light wasn't on but when i did the self diagnostic i got the code 14 which is the bad iacv. you have to find the jumper harness under the passenger kickplate by the ecu, it has two wires and a clip on the end. then bridge them and watch how it flashes.
try this link to check the code. https://honda-tech.com/zerothread?id=682412
dougshatch
10
06-11-2007 07:47 PM
allmotorEG-SI
07-20-2004 09:51 PM
