Spun Bearing
Spun Bearing
hey what's up guys, well basically i make this short and simple
Going to go pick up a White Eg coupe for 300$ with a D16y6 v-tec with a spun bearing, runs SUPER strong and the only reason i know it's a good car is my cousin told me everything about it and he would NEVER **** me over. He only bought the car for 700$ being it has Tokio Reds on it. Well my tech. question is how much and what do i need to fix a spun bearing? I did some research but couldn't find a nice detailed one besides something about replacing it and "Overhauling" your engine. Can anyone give me some insight on this? If it's an expensive and hard part i can pick the car up for 200-250$ nothing else wrong with it besides paint is only stage 2 not stage 3(About 1200$ paint job) and the door is purple and about 2 inches out of line(doesn't leak whatsoever though).
Re: Spun Bearing
I just drove the car not even 30 mins again and ran it up to 6k rpms 4-5 times, crossover is nice. The car runs extremely strong not even kidding lol. He says thats what he thinks is wrong with the engine(ls) and it was just causing it to not start. I can get the d16 for free with it and that's what i test drove today. The ls i drove about a week ago, less miles but the bearing needs to be fixed. Is it literally THAT BAD that you have to get a new engine? Everything i've heard about bearings is fixeable.
Re: Spun Bearing
Like i said i don't wanna argue about it but i do want some insight on it. So a spun bearing will cost me to repair and rebuild the WHOLE engine? jesus christ is this like the 2nd worse thing to a Rod knock? lmfao Well i'm getting the d16y6 vtec for free with it anyways so it will be running. I'm just garaging it will i'm going to work on it. Some bullshit happen with DMV so i have to wait until late oct to get my license(i'll be 18 that's why) so i'm not planning on driving it for a awhile and just going to trailer it to my friends shop and start building on. Money won't be a problem in about 3 weeks. I'll be working 60 hour weeks lol
The Grumpiest
Re: Spun Bearing
Who's arguing? Do the comparison. Will it cost more to repair than to replace? Answer that and you answer you own question. If you can/cannot do the work yourself, then factor that into the equation.
Re: Spun Bearing
That's the thing, i have no idea what it is or cost of a spun bearing? Do i just have to buy a bearing and fix it my self? ALL the work will be done by me and ANY help i need i have friends and family. 99% of all the work will be done by myself and any questions or help i can always get it. **** if i need a mechanic lift i have a shop 15 mins away to take it there as long as i want free of charge. what i want to know is what will be the cost to fix one of these? Something small like 100-200$ or somethign crazy like 600$?
Re: Spun Bearing
How about you just disassemble the D16 and have a machine shop tell you if the crank and journals are okay or not? If it is toasted then obviously a swap is the answer. If you can machine and run oversized bearings then why not?
Personally I would just sell the motor cheap (still could get $150 for the longblock or so) and put that money towards an LS swap.
Re: Spun Bearing
That's all i needed to know lol i've never dealt with or even had to deal with a spun bearing. I'm assuming a spun bearing is the Rod bearing? I can get almost any OEM part free from a local friend because i help out A LOT for nothing in return. So if i take it to a shop i need to from the the "Crack" "machined"? As long as i have detailed info on what i need to do i can go get it quoted tomorrow and get OVER a 50% deal on it if not free. If it's something i can't do myself i'll take the car tomorrow to my friends shop and ask him to help out. So to fix a spun bearing can someone make a simple list i can write down and have it checked out? i WANT TO KNOW what i'm working with and if i end up having to go to another shop i don't want to be ripped off.
Re: Spun Bearing
Re: Spun Bearing
Also if you're talking about the fact that i called it a y6 instead of a y8 is because my cousin is awkward/weird like that and called it that. I even looked it up to check where the **** y6 came from and it's just a New Zealand version of a d16y8(So i'm guessing he either knew that and called it y6 or for whatever really the motor is labeled y6 and the motor is from New Zealand) i personally just think he called it y6 instead of y8 lol
Re: Spun Bearing
My 2 cents
It's pretty easy to check the VIN and block/head codes.
Sounds like it may be wise to question a lot of what your cousin tells you.
Re: Spun Bearing
The irony is that the person who swore up and down you can't BAR and legally drive a K swapped EJ in CA also thinks you can BAR and legally drive a D16Y6 swapped car in CA.
Re: Spun Bearing
As I understand from your posts, you have the option to get the car with a working D16 or an LS with a spun bearing. Common sense tells me to go with the D16. If you wanted a bigger engine, just buy a used engine. There are a lot of low milage jap engines that cost the same or cheaper than a rebuild.
Re: Spun Bearing
Re: Spun Bearing
I can't find the law (I know, weird for me), but last I read said the motor itself must be available in the US. That doesn't mean it necessarily has to be USDM, it just has to have a direct USDM equivalent.
