spring rate question
in your opinion which spring rates would be best for streetability and autocross. im looking for a not too harsh setup. i have ridden in a car with 550/450 and that was very rough. which combo do you think is the best? thanks ahead for the replys.
Re: spring rate question (Ricey McRicerton)
Basically, to get the car to rotate slightly in turns. It brings the *** end around a little bit. A lot of guys/gals run slightly higher pressure in their rear tires also.
So why do you recommend lower spring rates in the rear?
bad-monkey
08-24-2004 05:24 PM
the DR.
12-25-2002 07:01 PM
