SPI WORKED 95 COUPE FOR SALE !!!!!!!
1995 RED HONDA CIVIC COUPE
107K BODY MILES... THE EXTERIOR IS STOCK PRETTY MUCH..STOCK TAILIGHTS.. JDM DENJI BLACK HOUSING HEADLIGHTS W/AMBER CORNERS..I ALSO HAVE THE CONNECTION FOR THE JDM FOGLIGHTS IN THE FRONT OF THE CAR WITH A SWITCH MOUNTED NEXT TO THE SHIFTER..U JUST NEED THE FOGS LOL
- THE INTERIOR IS MINT, THERE IS A 5" BLACK TACH MOUNTED DIRECTLY BEHIND THE SHIFTER WERE YOUR CUP HOLDER WOULD BE..AND THERE IS ALSO 2 GAUGES (AIR 2 FUEL & WATER TEMP)
47K ON LEGIT 99 B16A
-SKUNK 2 CAMS & AEM CAM GEARS (NOT INSTALLED..BUT WILL GO WITH THE CAR)
- ICEMAN INTAKE
- ARP HEAD STUDS
-2000 B16 HEADER AND 2000 SI EXHAUST
-HAD THROTTLE BODY
-aPEXI VAFC (TUNED BY SPI) ALSO HAS ADVANCED TIMING
- P72 CHIPPED ECU W/ NEW WIRING HARNESS
-MOTOR ALSO HAS ALL NEW GASKETS, FUEL & OIL LINES, WATER PUMP,TIMING BELT & ALL NEW VTEC SOLENOIDS & JDM CIVIC TYPE-R RED VALVE COVER
-1999 GSR TRANNY
-EXEDY AFTERMARKET CLUTCH W/FIDANZA LIGHTWEIGHT FLYWHEEL
-DC SHORTSHIFTER
-TYPE-R FRONT & REAR STRUT TOWER BARS
- SKUNK 2 UNDERBODY SWAY BARS
-EIBACH SPORTLINES ALL THE WAY AROUND W/ STOCK STRUTS THAT WERE REPLACED AT 90K MILES
--- THE SWAP WAS DONE ABOUT A MONTH AGO AND IS COMPLETLEY MINT..THE CAR IS CLEAN MAKES NOT ONE SQUEAK, RIDES SMOOTH & IT PULLS HARD..RUNS DEAD EVEN W/ TYPE-R'S, AND THATS WITHOUT THE SKUNK2 CAMS AND CAM GEAR INSTALLED .... I SPENT OVER 3500 JUST ON THE MOTOR ALONE..AND HAVE RECIEPTS FOR ALL WORK... i'M SELLING THE CAR B/C I'M MOVIN TO FLORIDA asking $5500....I'M TAKIN A LOSE BUT IT'S YOUR GAIN (908)966-1158
- ICEMAN INTAKE
- ARP HEAD STUDS
-HAD THROTTLE BODY
-1999 GSR TRANNY
-DC SHORTSHIFTER
coup3y
05-16-2011 05:37 PM
