speedometer going crazy.
Old 05-15-2004, 01:01 PM
frostcivic's Avatar
Default speedometer going crazy.
it's going wild when i am accelerating and slowing down. the speeds become random. what's going on? btw it's a eg civic si (1.6 litre vtec).
Old 05-15-2004, 01:06 PM
drewbie's Avatar
Default Re: speedometer going crazy. (frostcivic)
Your Vehicle Speed Sensor is not connected properly. Pull it off and blow in it and then reconnect it.
I bet it acts like a Tach sometimes
Old 05-15-2004, 01:11 PM
BlownVR's Avatar
well that same thing happened to me and it just happened one of the wires was a bit loose from the speed sensor so i just tighttened that up and it started working fine.
Old 05-15-2004, 01:41 PM
frostcivic's Avatar
Default Re: (H22BuiltEGhatch)
where would that be located?
Old 05-15-2004, 01:42 PM
BlownVR's Avatar
mine was located at the very back right of the engine bay where alot of wires are. it was a blue wire but your probably notice if it disconnected.
Old 05-15-2004, 02:51 PM
drewbie's Avatar
VSS plug is close to where you would full your transmission fluid.
Most people take the VSS off to fill the tranny
Old 05-27-2004, 12:26 PM
kaj
kaj's Avatar
Default Re: (Mr. Teal)
hey, time to bring back a dead topic
my speedo was working fine... then, i swap distributors and now it's bouncing like crazy.
my friend's speedo did this before his dist went out. coincidence??
Old 05-27-2004, 03:08 PM
allout_eg6's Avatar
CHECK YOUR DIZZY 90% CHANCE IT'S YOUR DIZZY MAYBE ITS GOING OUT USUALLY IT'S NOT YOUR SPEED SENSOR IF IT'S NOT PLUGED PROPERLY YOUR SPEEDO WON'T EVEN WORK. BUT I'M PRETTY POSSITIVE IT'S YOUR DIZZY MAYBE THE COIL.
Old 05-27-2004, 05:36 PM
kaj
kaj's Avatar
Default Re: speedometer going crazy. (allout_eg6)
that's what i was thinking.. my speedo USED to just stop reading.. go to 0 and stay there.. i took apart the VSS and solved the problem. the electrical connector was dirty, where it connected to the harness. now it won't go below my set speed. ex: if i'm doing 40mph, it will bounch between 40 and 80-100mph. weird. ONLY did this after putting on the different dist. OH! and i get a CEL now, but with no code. WTF??
Cmy4gD
07-11-2009 02:24 PM
b18 hatch mike
13
04-09-2008 06:51 PM
99Civic-EX
07-25-2007 11:44 AM
5 Skware
10-17-2002 01:39 AM
Quick Reply: speedometer going crazy.
