speedo problems need some help/info
just to start I did research and found a thread that was a simular problem. I posted and they said dont thread jack so here is my own thread. the speedo has not worked since I got the car 93 eg coupe, gsr engine/trans. replace the vss and the cluster. was testing the three wires that go to the vss. black, black-yellow and orange. you guys say that I only should get 5volts to the sensor? I tested 12v on the orange and the solid black was ground and the black-yellow strip was jumping 8v to 10v. Is the ecu bad? Im stumped I have pin out chart, wire diagrams what should I test next? today out of nowhere the speedo started jumping around like crazy and it worked for like 10 seconds. this is the only time it ever worked. checked gounds, plug ends for corrosion.
Re: speedo problems need some help/info
I have the same problem. Fuel pump won't switch on, MPH don't work, and My rpm stay under 2k even if im in 1,2,3,4,5 gear at any MPH.
Only thing working is Gas and Temp. Changed VVS and the whole 9 yards. Next step is to swap to JDM white face, can't go wrong then. |
everything else functions as it should but the speedo and I just bought another cluster for it
I am in the same boat, i am in search of a new cluster that do's not cost me a arm and leg to try and fix/dygnose the problem..
just paid 100 for one and didnt fix the problem.
Some good info there!
Id rather have too much info then not enough.. Nice find HPH:thumbup: Bookmarked! |
Originally Posted by BobbyRodriguez
(Post 46569772)
To much info
(Post 46569772)
To much info
(Post 46569772)
http://i68.photobucket.com/albums/i3...2511_front.jpg You have no problem busting out the voltmeter, but every problem in the world with an organized pool of information that will probably solve your problem? I'm confused. |
Problem fixed, ended up getting a brand new BAD vss. Thanks HondaPartsHero, I was able to diagnose the problem in no time with that info.
Originally Posted by sidsick65
(Post 46581890)
LOL!! You guys are jumping down sidsick's throat and he wasn't the one that even said "too much info" - that was BOBBYRODREGUEZ - which was not the OP!
