speed sensor will not work
i just put a B16A2 in my 92 hatch. everything works but the ecu is throwing code 17 (speed sensor) and my v-tech wont kick in and the speedometer wont work. i have put a new sensor on and am still getting the samething. i have even rewired the sensor and it still does nothing! i could care less about the speedometer i just want the vtech working right !
1 Post
Re: speed sensor will not work (dohceg6)
I hate it when my phone doesnt work too. Seriously though. did you replace it with a good working sensor? If so then I would invest in a continuity tester and check the wiring back to the ecu.
Unceasing Measure
Re: speed sensor will not work (monicle)
Yeah, it's probably just a bad sensor...them and the gauge cluster wiring go bad all the damn time. Replace it.
AND FOR THE LOVE OF CHRIST, IT'S VTEC, NOT V-TECH.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohceg6 »</TD></TR><TR><TD CLASS="quote"> i just put a B16A2 in my 92 hatch. everything works but the ecu is throwing code 17 (speed sensor) and my v-tech wont kick in and the speedometer wont work. i have put a new sensor on and am still getting the samething. i have even rewired the sensor and it still does nothing! i could care less about the speedometer i just want the vtech working right !</TD></TR></TABLE>
It could either be a bad sensor or worst, which is a bad differential.
take out the VSS from the transmission and check where the VSS meets the differential to see if everything is in place and not loose...my differential broke and would not spin the gear on the speed sensor
Re: speed sensor will not work (soopafly828)
well i have the same problem and i replaced the vss and the cluster. what do i check on the linkage? i stuck my finger in the hole where the vss came outta the tranny and nothin moves.
nenacivic23
08-30-2004 03:18 PM
