Speaker Install/Door Panel Removal?
Is it possible to install front speakers without removing the door panels? If so, how?
If not, then how do i remove the door panels and window crank? I could probably figger it out on my own but i like pictual writeups
Re: Speaker Install/Door Panel Removal? (I'll cut ya!)
The grills pop out of the door panel giving you acceas to the speaker mounting screws. Otherwise if you want to remove the door panel (I dident) remove the window crank, remove the door handle (One Screw) and remove the panel screw (One screw located beneath the door handle) and then pop the bottem of the door panel off to get the clips out and push up when its free, Install is reverse of removal......
Id take pics but im at werk right now
I am a (Trial User) Army
Re: Speaker Install/Door Panel Removal? (nocternaldragon)
there is one screw in the coin tray.
one screw in the inside door handle (lift handle and you'll see it)
and one screw right underneath the mirror.
the window crank is the hardest part. there is a c-clip that is sometimes hard to reach. you need a long screwdriver to reach it and just push it down and it'll pop off. after you take off your first one it'll be alot eaiser the next time once you understand how it works.
after you take off the 3 screws and the window crank the door will still be held in place by the clips on the inside that are attached to the metal frame. to take off the door simply pull at it slowly and gently so that you don't break the clips. start pulling at the part right under the mirror then work your way across the top part of the door, once done, the bottom will come easily out.
takes about 2 minutes
serious
09-06-2002 04:40 PM
sicilian2k1
Audio / Security / Video
08-21-2001 03:52 AM
