Sparkks racing map senor? Is it good should I use it??
Re: Sparkks racing map senor? Is it good should I use it??
Ben, we've got to know more about your setup and what you're trying to do. First, I've never heard of this company - not necessarily a bad thing, but they probably aren't a huge player. Second, looking at their website, their MAP sensors are only $35 where the rest of the industry has them closer to $100 - this is a red flag for likely being a cheap Chinese knockoff. You could try it and it could work, or it may not work, or it may only work for a couple of months, then you're going to have to buy another one. There are worse scenarios too if the sensor doesn't just completely die and instead gives false readings which could lean the engine out and tear up all kinds of stuff. Why not just go with a reputable company? Also, these are 3 and 4 bar sensors, which will not work with the stock ECU - are you running an aftermarket ECU which can support an aftermarket MAP sensor? If not, stick with an OEM Denso sensor.
