Spal Window Kit Question
ive searched for these on the board and found couple good topics. but i have not found the answer to my question.
i want to install the kit on my cx and put ex door panels on afterwards and use the oem honda switches. i hear that the window crank has to stay there which means that my door panel wont fit over it without cutting a hole in the panel for the crank to stick out.
i def do not want to buy the kit if i have to cut a hole in the ex door panel, that is tacky.
any imput? thanks in advance
Re: Spal Window Kit Question (NitroSign)
Just look for 2 EX doors and swap over the internals and what not but the spal window kit will probably be your cheapest bet. 2 EX doors with all the internals will probably run around 200+ depending on condition but since you just need the internals you might be able to find some beat to **** ones.
Re: (NitroSign)
I know that's what i just said but you said you want the ex door panels which isn't gonna happen cause you need the crank...although with the Spal Window kit they do give you a plug to plug the whole where the crank is. Just cut a hole the same size as the one in your door panels now and use the plug and it'll still look clean.
well is there anyway to cuttoff some of the crank so its possible not to have to cut the panel?
either way im not buying to kit if i have to cut the panel.
Re: (NitroSign)
I don't think so....Check out this install it looks like they actually went over the whole crank http://www.geocities.com/bellz252/pd...0kit%20install
Re: (Happyman)
ya that doesnt look bad, i didnt read it but i dont think it was a honda. so that might matter. i think i would get away with it by cutting off some of the crank. hopefully someone who has done this before takes a look at this thread.
turbohf
09-06-2006 11:17 PM
