soooo that D build failed!
Old 01-21-2011, 07:24 PM
k5egg's Avatar
Default soooo that D build failed!
Sooo... 20 minute idle + 45 miles of careful breakin lead to this:
http://www.youtube.com/watch?v=fIAEEDrlv2Q
Yes, I realize I should have stopped, but where I was lacks cellular coverage from any carrier other than Globalstar and Iridium. I was also pretty pissed off.
I haven't torn it down yet. After the bearing(s) spun, I drove 8 miles back to civilization - then proceeded to get pulled back to my house (30 miles) by a Hyundai Santa Fe LX and a strap, in the rain, in the dark (FAIL!).
Sooooo, I think I'ma be looking for new rods and crank. The block was quite sexy and the compression was good after the 20 minute idle and 7 miles of gentle driving.
In hindsight, I think I should have replaced the oil pump.
So, anybody in TX, LA or AR want to sell me a D16 bottom end?
Old 01-21-2011, 08:18 PM
itsmejto's Avatar
Default Re: soooo that D build failed!
YOU DID AN ENGINE REBUILD AND USED THE OLD OIL PUMP.
Shame on you, you deserve all you got.
Old 01-21-2011, 08:19 PM
strategy400's Avatar
Ouch. I have a D15B7 long block in the garage but I was gonna freshen it up for a spare.
Old 01-21-2011, 08:23 PM
2000silvercivic's Avatar
I have a d16y8 block with the crank still in it sitting in the garage. But im in Indiana.
Old 01-21-2011, 09:08 PM
k5egg's Avatar
I wouldn't call it a rebuild - more just a "bearing swap, ring replacement, and a new head gasket"...
I didn't want to go through the effort of pulling the engine. The weather sucks and I have no decent place to work. Guess that excuse didn't impress the Honda Gods enough to cut me a break.
I mostly did this in hope it would survive until late spring when I intended to do a complete teardown and rebuild w/ machine work. No go.
Luckily I have secondary transportation, its just less fun and sucks gas (everything sucks gas compared to an EG, I was getting 38-40 mpg before the rod bearings gave out the first time).
This was an experiment in doing as little as possible, and it (almost) worked. I was banking on chemical breakdown of the bearings from sitting 7 years with used oil in it. I suspect the actual problem was insufficient oil flow.
Rob97'SH
05-07-2013 04:47 PM
ltrkstr2k
Mid-Atlantic (Sales)
10-11-2012 03:26 PM
daymkimchee
30
04-20-2009 08:20 AM
400WHPITR
01-30-2006 11:25 AM
green91
04-17-2004 10:28 AM
Quick Reply: soooo that D build failed!
