power steering for b18b into ek
Old 04-07-2003, 06:34 PM
streetspeed's Avatar
Default power steering for b18b into ek
We are putting a b18b into a 98 Civic. What power steering pump and power steering lines did some of you use in your conversions. thanks...
Old 04-07-2003, 06:59 PM
Foozball26's Avatar
Default Re: power steering for b18b into ek (streetspeed)
When I put a 95 LS into my 98 Civic I had to get a power steering line from an older honda b/c my fitting on the 98 Civic line was too big to fit in the LS pump.
So I had tony from jotech cut and weld the small fitting on the 98 civic line, works perfect.
Old 04-07-2003, 08:42 PM
Default Re: power steering for b18b into ek (foozball-26)
anyone else have any experiences with this.
Old 04-07-2003, 08:49 PM
youngkow's Avatar
I put a 2000 b18b into a 99 lx, and i used the pump that came with the b18b. Everything just bolted right up. The steering did feel a little lighter, so I took the pump out.
Old 04-07-2003, 09:40 PM
Default Re: power steering for b18b into ek (youngkow)
The line that is in the Civic does not match up to the Integra pump. Is modifying it the best alternative?
Old 04-07-2003, 09:41 PM
Darth ModerVader
Padawan's Avatar
Why not just leave it out?
Old 04-08-2003, 04:54 AM
Foozball26's Avatar
Default Re: power steering for b18b into ek (Padawan)
b/c power steering kicks ***, its not a workout when trying to park.
You can do one of two things, do what I did and have someone weld the right fitting on, or goto a junkyard and find a hose that bends the same way as your civic one and still has the smaller fitting.
The first is the easiest and cost me $15
Old 04-08-2003, 06:51 AM
youngkow's Avatar
What year is your pump, because mine fit fine. No modifications necessary. Mine was a 2k b18b into a 99 lx.
*edit* Sp.
[Modified by youngkow, 9:55 AM 4/8/2003]
Old 04-08-2003, 09:41 AM
Darth ModerVader
Padawan's Avatar
Well I suppose it's personal preference, because removing the PS on my car was one of the best and most cost-effective modifications I ever made to it. With the components removed and the rack looped, steering effort was never an issue, and steering feel and feedback were greatly improved, not to mention the reduced weight (~16 lbs, roughly equal to installing a CF hood) and the freed-up power (4-5 whp on a B-series).
Old 04-08-2003, 09:43 AM
IS3Fifty's Avatar
just leave what you have in the car and mate it to the LS parts that came with the motor....
Old 04-09-2003, 04:53 AM
Foozball26's Avatar
Default Re: power steering for b18b into ek (purek9hybrid)
yea it is personal prefrence.
a d-series power steering pump wont fit on the b18b, I've tried before i had to get the fitting welded.
the pumps are year specific so depends on what year motor you have to whether or not he is gonna need to change the fitting.
khailon
05-07-2011 10:47 AM
SIRIUS EJ8
07-08-2006 12:16 AM
Touge Tuning
10-15-2005 12:51 PM
PUSHER
05-09-2003 07:36 PM
Turbo Powa
12-16-2002 01:33 PM
Quick Reply: power steering for b18b into ek
