SOMEONE PLEASE HELP ASAP!! wiring problem on JDM ITR front end conversion
So heres the problem, Im workin with an 94 LS with an ITR front end conversion, having problems with some wiring for the headlamps... I got the headlights to work, high and low beam, the fog lights are workin, and also the little amber lights in the high beam casing are working...BUT no blinkers, left or right! the green arrows in my cluster don't even come on! The hazord's come on, and the two outside amber lights work, but no blinker. I checked the fuses, nothings wrong. Am i missing a relay or some other fuse? please help! a diagram would be nice, but if anyone has ever wired up JDM ITR headlamps, gimme so info! thanks HT... P.S. its f*cking cold outside! so the frustration is setting in much quicker
Re: SOMEONE PLEASE HELP ASAP!! wiring problem on JDM ITR front end conversion (20civic00)
dont let me down guys! bump to the top to get some answers!!
I am in the process of doing and ITR conversion on my 00' LS. Had some questions about wiring the headlights up. Any info would be greatly appreciated.
Re: SOMEONE PLEASE HELP ASAP!! wiring problem on JDM ITR front end conversion (1rrobert5)
this is the wrong forum for this it should be in integra but here is a write with wiring details at the end https://honda-tech.com/zerothread?id=1346217
I know that, for example, in the past, if I had undone some other switches, say, the hazard button, it interrupted the circuit and my blinkers didn't work anymore. However, when I plugged the button back in, they worked again. I think sometimes you need to have everything connected. With a front-end converson, make sure other things aren't disconnected at the same time. Hope this helps.
fast2camciv
08-23-2007 12:05 PM
SP GARAGE
08-10-2007 09:47 AM
MikesGSRbuiltEG
12-11-2006 11:32 PM
