SoL wastes too much gas :( 200 miles per tank
Ever since i swapped my engine from
a "D" to a "B" ive been getting the worst
gas milage... when i had the "D" i use to
get 400 miles per tank...and now its only
a lil over 200 miles...which sucks because
i spend close to $30 a week..... any help!!
i was reading earlier and i read that it could
be the CEL i checked the codes and the only
codes its throwing outis my vtec and my knock
sensor (im running a jdm p30)
its an jdm automatic "B-series" btw
lmk know peeps im wasting to much gas....i have
to trap my self in the house in order not to waste gas
HT peeps
HT peeps
Bad MAP sensor.
Bad primary 02 sensor.
Poor functioning TPS.
Poor IAVc (mainly if your car isnt idling).
Bad driving habits.
Bad fuel injection/fuel filter.
Wrong oil viscosity.
Bad air filter.
Clogged exhaust.
Poor ignition/bad fuel burn.
Improper timing.
Bad tire pressure.
Improper alignment.
Carbon buildup.
All just off the top of my head, pick your favorite.
Bad driving habits.
Bad air filter.
Clogged exhaust.
Improper timing.
Bad tire pressure.
Improper alignment.
Carbon buildup.
Re: (97Ej6mike)
you should be able to pull 300-350 miles to a tank (unless you have a VX, then it's 250-300 due to the smaller tank)
unless this is an auto trans setup. then it's decreased from there. (you mentioned an auto ECU but not the CEL19 that comes with auto trans ECU with manual trans setup)
Are you running a chipped ECU? (death to mpg figures unless it's tuned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">Going Bad MAP sensor.
Going Bad primary 02 sensor.
Bad driving habits.
Bad air filter.
Clogged exhaust.
Improper timing.
Bad tire pressure.
Improper alignment.
Carbon buildup.
All just off the top of my head, pick your favorite.</TD></TR></TABLE>
agreed, but I fixed the MAP and O2 references. a bad sensor will set a CEL.
another thought is the CELs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">i checked the codes and the only codes its throwing outis my vtec and my knock sensor (im running a jdm p30)</TD></TR></TABLE>
the knock sensor CEL may cause a decrease in mpg readings, also the VTEC issue will cause the car to not run even close to it's potential. Which may cause you to drive it differently. (ie foot to the floor more often, with eats fuel)
Fix those CELs and the car will run better, should ever get better mpg when you keep your foot off the floor. Which after a D to B swap is difficult to do.
Bad driving habits.
Bad air filter.
Clogged exhaust.
Improper timing.
Bad tire pressure.
Improper alignment.
Carbon buildup.
Cool Cool Island Breezes. BOY-EE
Re: SoL wastes too much gas :( 200 miles per tank (Fake)
fix your CELs. WHICH automatic B series?
Besides that, do you figure that maybe your bad gas mileage stems from the fact that you just got a new mod...and you keep wanting to "test" it out?
Re: SoL wastes too much gas :( 200 miles per tank (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious »</TD></TR><TR><TD CLASS="quote">fix your CELs. WHICH automatic B series?
Besides that, do you figure that maybe your bad gas mileage stems from the fact that you just got a new mod...and you keep wanting to "test" it out?</TD></TR></TABLE>
yeah i need to fix my CELs ....its a B16A2 with the auto tranny....i've had my engine for about 6 months and evrey week im putting 30 and im tired of wasting fo much
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">you should be able to pull 300-350 miles to a tank (unless you have a VX, then it's 250-300 due to the smaller tank)
Fix those CELs and the car will run better, should ever get better mpg when you keep your foot off the floor. Which after a D to B swap is difficult to do.</TD></TR></TABLE>
yeh i no i should at least pull more then 200...200 its just insane...yeh i need to check out my CELs....i tried fixing my vtec but ended up not working still threw the code..iuno i got re try it
preludepower
10-06-2009 08:24 PM
